should I step up to 25inchers?
Old Jul 3, 2002 | 11:32 PM
paulzy's Avatar
Default should I step up to 25inchers?
Right now, I'm currently have 24.5x8x13 MT slicks on my bogarts. My new motor should be ready by mid July or a little later. I'm hoping for around 400-450whp with around 20 some pounds of boost.
Do you guys think I would be ok with the 24.5" or should I go up to a 25" from M&H?
Old Jul 3, 2002 | 11:56 PM
ninesecrx's Avatar
Default Re: should I step up to 25inchers? (Slow_ass_4dr)
I would keep that size slick if it were me. I have considerable more power then that and still run the 24 talls.....Mike
Actually I just saw you only have the 8 wides. Maybe you should step up to the 24.5 by 9.5 wides? Give you a little more foot patch. Thats the size we run.
[Modified by ninesecrx, 8:57 AM 7/4/2002]
Old Jul 4, 2002 | 10:50 AM
paulzy's Avatar
Default Re: should I step up to 25inchers? (ninesecrx)
I was thinking abotu taht too, but I'm not sure if my axles would take the beating of the fatter, wider slicks..
I currently use DSS stage 3
Old Jul 4, 2002 | 11:51 AM
earl's Avatar
IMHO, it's not about the width, it's the height that hurts you. You could hook that combo with 22x9's but depending on rpms, might have to shift into 5th gear.
Old Jul 5, 2002 | 11:57 AM
jinxproof99's Avatar
New User
Default Re: should I step up to 25inchers? (earl)
yeah, it depends on your gearing. shoot for the top of your powerband in 4th gear. tire size, tranny, final drive, and rev limit all control where you will be when you go through the traps. depending on your rev limit, with 425 hsp to the wheels, and 25 inch tires, you could run a type r tranny. or run a gsr tranny with 24" tires. you NEVER wanna be in 5th gear through the traps.......but you also don't wanna be at like 6000 rpms in 4th (with a say a 9000 rev limit). takes alittle testing.
Old Jul 6, 2002 | 04:11 PM
lsvtec-crx's Avatar
out of curiosity what is your setup.
Old Jul 6, 2002 | 06:23 PM
paulzy's Avatar
Default Re: should I step up to 25inchers? (lsvtec-crx)
built ls/vtec turbo in a civic 4dr boosting high and controlled with a haltech
See Are X
Sep 14, 2008 12:40 AM
DRAGWORKS
Aug 31, 2006 08:48 PM
THCk20eg
Oct 23, 2004 02:14 PM
londa hover
Aug 23, 2004 04:52 PM
londa hover
May 22, 2004 12:21 PM
