throttle body question
* B A N N E D *
i have a b16 with a skunk2 manifold i wanna get another throttle body wider in diameter can i get a b18 throttle body with no mods or which throttle body can i get for a b16 1st gen??????
If your B16 is a first gen then your TB is 58mm stock diameter. It can be bored to 62mm. Your manifold has a 64mm opening. The best combo would be a 64mm throttle body which you could have if you bore any OBD1 or newer B series TB. Those are 60mm stock and I can bore them to 64mm with a 67mm tapered opening
I don't know how good the aftermarket TBs are.
Ask here for opinions about the one you are considering to buy.
The manifold can be bored to 70mm no problem
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by juanchoenuncrx »</TD></TR><TR><TD CLASS="quote">what happens if i put a 70mm throttle body on a 64 mm manifold is it normal or will i have problems???????</TD></TR></TABLE>
It's not going to be a problem, but you're airflow is going to suck if you don't port match the mani.
1baddturbosi
Feb 18, 2007 07:36 PM
