D16 turbo problems
Old Feb 13, 2008 | 02:53 PM
jonny_sin's Avatar
Default D16 turbo problems
ok so i had the cam gear break off a while back and the head was redone and re surfaced.
i installed the head and is perfectly on time but i have a rowdy misfire in piston #2
i can remove that plug while running and there is no change in the way the motor works . i replaced the plug and just recently replaced the injector but the same misfire is there well it got a little better but still have it there...
i don't know if i should have posted it here or in the forced induction section..
Old Feb 13, 2008 | 03:05 PM
ObedD15's Avatar
Default Re: D16 turbo problems (jonny_sin)
I would check the cap and rotor to see how everything looks under there. Then if you have another set of plug wires try slaving one in and see if its that. If still nothing I would pull the distributor and check for play in the bearing , corrosion on the electrical components. Good luck
Old Feb 13, 2008 | 03:17 PM
jonny_sin's Avatar
i did that already and still nothing
honda4674
Oct 1, 2013 10:15 PM
b20bFourDoorCivicLX
May 28, 2012 09:39 AM
crick_james
Nov 21, 2008 05:28 PM
SIlent92EG
May 25, 2004 02:35 PM
B_CRUZ!
Feb 14, 2002 08:45 AM
