What will i need to use this?
Old Jul 3, 2002 | 10:36 PM
hondacivic4g's Avatar
Default What will i need to use this?
I've tried a search and no one is using an SI, all are using HF or DX or STD.
Still the only thing i found lost me in the responses.
So here are my questions, if I'm swapping D16Z6 into a 90 SI hatch.
And I want to use the p28 ecu, what wiring do i have to do?
Just have to modify the wiring harness right?
Add a few wires going from ecu to activate the Vtec or is there more to it then that?
Since the car is set up for MPFI there shouldn't be any big changes there right?
Well thanks for any info.
Old Jul 3, 2002 | 11:40 PM
ViperRedCRX's Avatar
Default Re: What will i need to use this? (hondacivic4g)
it won't match color for color, but get a manuel, like a chiltons or something like it (not a haynes) and wire in the obd1 ecu plug one wire at a time to the right sensor.. will take a few, but it's pretty easy
KZK civic
Jan 10, 2012 01:46 PM
Xemu
Oct 18, 2006 04:29 AM
four20jnd
Aug 30, 2006 06:01 PM
hatchblack
Jan 1, 2004 08:04 PM
91hatch_on17's
Jan 31, 2003 08:34 PM
