Cometic .074" head gasket. Are they reliable?
Old Feb 13, 2008 | 11:35 AM
TwoKSiR's Avatar
Default Cometic .074" head gasket. Are they reliable?
I jsut got mine and damn it's heavy. I am just blown away by how thick it is. It's a monster. Are they reliable? I need to keep my compression down in the 11.2:1 range. It just seems to think to be reliable.
Old Feb 13, 2008 | 11:43 AM
( o )( o )'s Avatar
Default Re: Cometic .074" head gasket. Are they reliable? (TwoKSiR)
I used that exact model....I did have a small coolant leak but it didn't matter because I just used it to lower the compression so that I could run the stock ECU to pass emissions testing. After that I put the stock gasket back on until the next emission test 2 years later (which is due in about 2 months)
Old Feb 13, 2008 | 01:02 PM
4g hatch's Avatar
Default Re: Cometic .074" head gasket. Are they reliable? (( o )( o ))
i running the .051 right now and havent had any problems in 6 months,well only around 3-4000 miles on it though. make sure each mating surface is perfectly clean and flat. if there is any old gasket left from what i seen they dont like to seal well
RICE POLICE SIP
Sep 18, 2003 08:31 PM
Evs-One
Mar 3, 2003 01:09 AM
