h23a1 head + f22b2 block = ?
Old Feb 13, 2008 | 08:23 AM
h22a_black's Avatar
Default h23a1 head + f22b2 block = ?
ok ive done a search but I couldnt find anything regarding this particular combo... would it work?? basically i have a wrecked prelude sr with the h23a1 in it so i can get the head for free, but its got 350k km on it, so im guessing it would need to be rebuilt?
do you guys think it would be worth it?
Old Feb 13, 2008 | 10:08 AM
Derek128's Avatar
Default Re: h23a1 head + f22b2 block = ? (h22a_black)
h23 head + f22 block = g22 or g23
just rebuild the head
then u r gd to go
r u planning to turbo? cos ur c/r will be lower after this head swap
Old Feb 13, 2008 | 10:29 AM
not-a-stang's Avatar
Default Re: h23a1 head + f22b2 block = ? (Derek128)
how much lower? I have access to an H22 head, and wondered how much, if any, performance can be gained by using this head on the F22? This no piston swap/build up, just a straight swap.
Old Feb 13, 2008 | 10:55 AM
Derek128's Avatar
Default Re: h23a1 head + f22b2 block = ? (not-a-stang)
Correct me if i'm wrong
it will bring it down to 8.5(from 8.8) or so
Old Feb 13, 2008 | 04:31 PM
CD5 Jeebies!'s Avatar
From: Free bullets if you find me sucka, Washington
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Derek128 &raquo;</TD></TR><TR><TD CLASS="quote">h23 head + f22 block = g22 or g23
then u r gd to go
r u planning to turbo? cos ur c/r will be lower after this head swap</TD></TR></TABLE>
your tripping dood...yes that paticular combination of parts will produce a G series motor...It will not LOWER your compression it will RAAISE it...there is alot on HT about his swap..search for topics created by piratemcfred or prelittlelude...I read ror days about it.....GL man
69corey69
Jun 13, 2017 05:56 PM
PreLuder96
May 3, 2009 05:58 PM
deeweezy187
Sep 12, 2006 09:43 AM
hybridpatient95
May 9, 2006 10:43 AM
