Engine rattle getting louder
Old Feb 13, 2008 | 05:47 AM
Quade's Avatar
Default Engine rattle getting louder
Alright alright I have an H22 vtec lude and I have an engine rattle that occurs when lifting the throttle slightly and between shifts. Idle is fine and holding rpm around 1500 in neutral gives a constant rattle. Performance is still there. I did plenty searching and I'm not sure if it's the head or block at fault. Gonna do a tear down this weekend but would like some headsup on what to look for. Thought I would raise a couple old threads with this kinda problems but apparently some members don't like that. However, anyone experiencing this problem before please feel free to chime in.
Old Feb 13, 2008 | 01:02 PM
h23troici's Avatar
Default Re: Engine rattle getting louder (Quade)
If the rattle is coming from the crank shaft area you may have spun a bearing that can lead to a rod knock. I know with my prelude after I hit 100k I change all the bearings.
Old Feb 13, 2008 | 05:47 PM
jonnysplace's Avatar
Default Re: Engine rattle getting louder (h23troici)
Same prob with built h22 spun rod bearing seems common.If you dont drive the car it can be saved but youre gonna need a crank also
Old Feb 14, 2008 | 04:20 AM
Quade's Avatar
The rattle seems like it's in the head.
Old Feb 15, 2008 | 07:11 AM
1998_Lude's Avatar
This problem only occurs when you lift the throttle?? Also, is it a "ticking" sound or an actual rattle sound? If it's a ticking sound i would suggest doing a valve adjustment. If its a rattle, is it a higher pitched rattle like a valve, or is it a deeper sound like maybe larger head components loose? if it's higher pitched i would say try a valve adjustment first and see what you find with the VC off. If it sounds like larger components rattling then take the VC off and see if anything is loose. If it sounds like its the block, then most likely is sounds like a knocking rod, and could be as easy as a bearing replacement. But i would be easy on her until you completely diagnose the problem. Good luck and let us know what you find!
Old Feb 19, 2008 | 04:54 AM
Quade's Avatar
Default Re: (1998_Lude)
No1 and No4 conrod bearing spun/knock. Gonna start overhauling my standard block. Block was built with eagle rods and ACL bearings.
nycpatron
11
May 21, 2010 07:22 PM
ncskate1985
Jan 26, 2008 12:49 PM
dacrxkid4rm253
Nov 29, 2007 12:07 PM
esteps
Oct 9, 2005 02:11 PM
defaced
Feb 19, 2004 04:13 PM
