Rotate the entire rotating assembly???
Old Feb 13, 2008 | 04:22 AM
philliedawg's Avatar
Default Rotate the entire rotating assembly???
I was reading Bambam's "how to build a realiable lsvtec/b20vtec" and he said rotate the entire assembly. I don't get that. As this is my first build, when should i know when is the right time to rotate the assembly while in the build???...Please help guys...Thanks.!
Old Feb 13, 2008 | 05:57 AM
98vtec's Avatar
moderator emeritus
Default Re: Rotate the entire rotating assembly??? (philliedawg)
huh?
i think you need to go back and read what he said.
Old Feb 13, 2008 | 06:08 AM
alterdcreations's Avatar
maybe......
Balance the rotating assembly?
Old Feb 13, 2008 | 06:12 AM
TODAwhore's Avatar
Default Re: Rotate the entire rotating assembly??? (alterdcreations)
or maybe to rotate it after installing each piston..
Old Feb 13, 2008 | 11:20 AM
King V's Avatar
I think he meant to rotate the assembly to check for binding or clearance issues. IE, after you put the bearings in No 1 conrod, give the crank a spin to make sure it rotates freely.
Old Feb 13, 2008 | 08:13 PM
-Darren-'s Avatar
rotate to make sure everything is rotating smoothly without any type of interference, also do this after you've installed the head w/the timing belt.
haas480
Mar 7, 2010 08:06 AM
musikpal
Aug 28, 2009 08:38 AM
m00nr0ck Si
May 31, 2008 07:22 AM
Boostedb20EH2
10
Mar 10, 2008 04:36 PM
Silude
Jun 8, 2001 05:43 AM
