FS: B series & D series parts
Old Feb 13, 2008 | 12:53 AM
FOMULA91's Avatar
Default FS: B series & D series parts (Update 05-30-09)
My Voucher List
SOLD to:
Itslogz – AEM Cam Gear Bambbrose – OBD0 Injectors Krisfnbs – 2 Hydro VSS harmonator84 – PR4 ECU
Mr_CRX – DA VSS 24TEN – GSR T cover, D16 IM ekillah – OBD1 IACV RSZero1 – PR4 ECU
ca-rs – HF CAT JayGee625 – OBD0 IACV Fonkernuckle – VTEC solenoid mgs1098 – Hydro VSS
slowlittlewhitey – OBD1 IACV b18vtecboi – D Mount FG2 chilotz – OBD1 IACV Obuhmyuh – IACV
Blazinearth – ITR IM SawBoss – P72 PS Pump EJ2-Fluffy – radio, MAP sensor dkboyny11 – ITR CAMS
agustin – Jump Harness stellhornata – cable VSS 95singlecamvtec – MSD cap 818blue818 - FITV
ptftw - Distributor myfirstdc2 – OBD1 injectors eg-perk – ECU connector Navy_CRX – AEM fuel rail
88civic - vtec solenoid triphop718 – ECU connector ==Catfish== - B-series motor mount bracket
srt4pilot – D series motor mount bracket Reza^ - OBDI injectors Group Tenacity – PR3 A/C bracket
EGR95 – B16 Intake Manifold socalJDMer – OBDII injectors d_EG COUPE – traded VSS with ITR LCA
MonKK – OBD0 injectors dpetro1 – IACV boo5tedteg94 - OBD1 injector platinumg2 – B heat shield
EFin' Kyle – CRX R1 coilover Thegoatc – harness plugs Littlekeel – OBD1 engine harness 91(si)hatchey – ECU plugs
Gsrswapdcivic – VSS eggsi619 – B heat shield dubs97integ - Si Harness Spunkster - DA 1/2 Shaft XxDrUnKnMuNkxX - OBD1 IACV sillyboi - B-series post mount bracket thresher – OBD0 IACV k2kyl - VSS mRek9R - injectors b18vtecboi – rotors llslick - injectors Cambocheen! – torque mount 91redrex - VOLKS rim Budget Racer - IACV choptopprelude - refunded money screen_name - 97 Toyota Camry MOE@Hyper16Valve - Si hubcap k20 kid – IR Sockets zoopreme – DVD Player llicea05 WRX EXEDY Clutch ibevila – Stock Motor Mounts HRC51 - VSS ecosol - VTEC harness kevinthefawker - axles
defythemall1 - D16Y7 TB [eg6] - exhaust manifold dc5itracer - thermo housing rugimpy - Gameboy godluvstegs - Crank Sensor dc5itracer - Thermo Housing Mashi2Choco - EK NRG Hub suzieffbaby - Oil Pan & NRG QR heho - Radiator kn0tz Intake arm [eg6] - Exhaust Manifold
BOUGHT from:
88crxsir – CRX door skirt bluebird – D15 Vtec Nerologic – Many things Mr_CRX – Many things
Outsane – CRX corner light, door panel LoSt is BlaCk D15 Timing cover 24TEN – Si Seats
DC2SIR-G – GSR transmission Alanicious – linkage, RSR exhaust Trimugenhatch – B16 long block Del Sol SiR – USDM P30 ECU
Oinojo – B16 swap mccoy1178 – P30 IM Your Name – BBK TB SlowSOHC-T – NGK wire
1990CRXSIJDMEF8 – Craftsman tool box eg2jr – CRX B pipe grip200kg – TSW fourthgenhatchB17 – Bunch of SOHC
iownahatchback – D16Z6 Intake Manifold JDM_JNKY – B16 cams f@sth@tch89 - P28 ECU em1loc – P61 ECU
mabbiker – Speaker plate + AEM silentdaredevil2 – OBDI harness skavenger*ef9 – CRX head light + H&R spring w/ strut
Ldo – CRX T-bar & ½ shaft frank_el_tanke – JDM wire harness + B16 IM #1DA2HATE – B-series TB
snowboardgeek1 – EX cluster + spoon mirror ThatGreenGsr – 92-93 GSR CAMs Radim – HKS short ram
LS94tegra – D16Z6 Dizzy da9leo – DA Cat WICKED.OSS - MOMO virdizzeripsta - Seafoam .Manny. - eibach B2FiNiTY - Muteki notoRious1 - used tire 3rdgenLS – Racing shoes 424racer – CRX Distributor kaduku_ - Steelies thresher - Mishimoto hose hybrid89 - CRX Center Garnish jdm ek o - B16 TB & **** Stunna MIKE - D16A6 IM truongmai8d - Light Crank Pulley PYITR01 - ITR Harness volcomstoned - Test Pipe JDMH22HATCH - Honda MTF Ed7touge - PW Intake 90goldhatch - JG Cams Innes - Revo Camber Kit Back2JDM - CTR Harness rugimpy EG Clock TranceAddicts - D16Y8 IM hybrid89 - CRX Garnish SpeedFactoryRacing - Battery Stunna MIKE - D16A6 IM truongmai8d - Crank Pulley PYITR01 - Harness jdm ek o - Shift ****
Old Feb 13, 2008 | 09:02 AM
FOMULA91's Avatar
Default Re: FS: B series & D series parts (FOMULA91)
Old Feb 14, 2008 | 12:11 PM
FOMULA91's Avatar
Old Feb 17, 2008 | 09:36 PM
FOMULA91's Avatar
Old Feb 19, 2008 | 07:02 PM
FOMULA91's Avatar
Old Feb 19, 2008 | 07:24 PM
eg6low-buck's Avatar
BUMP!!!
Old Feb 19, 2008 | 08:32 PM
FOMULA91's Avatar
Default Re: FS: B series & D series parts (eg6low-buck)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eg6low-buck &raquo;</TD></TR><TR><TD CLASS="quote">BUMP!!!</TD></TR></TABLE>
Thanks bro.
Old Feb 21, 2008 | 11:16 AM
FOMULA91's Avatar
Old Feb 24, 2008 | 04:17 PM
FOMULA91's Avatar
Old Feb 25, 2008 | 07:54 PM
FOMULA91's Avatar
ttt
Old Feb 27, 2008 | 01:18 AM
FOMULA91's Avatar
LS IACV pending.....
Old Feb 27, 2008 | 06:47 PM
FOMULA91's Avatar
LS IACV SoLd
Old Feb 28, 2008 | 11:23 AM
FOMULA91's Avatar
Old Feb 29, 2008 | 09:05 PM
FOMULA91's Avatar
up before work....
Old Mar 1, 2008 | 08:38 PM
FOMULA91's Avatar
up for work
Old Mar 4, 2008 | 11:45 AM
FOMULA91's Avatar
Old Mar 5, 2008 | 11:55 PM
FOMULA91's Avatar
ttt
Old Mar 8, 2008 | 04:23 PM
FOMULA91's Avatar
BumP!!!
Old Mar 9, 2008 | 06:17 PM
FOMULA91's Avatar
D16Z6 IACV Sold
Old Mar 10, 2008 | 07:40 PM
FOMULA91's Avatar
PM8 ECU pending...
Old Mar 11, 2008 | 11:50 AM
FOMULA91's Avatar
waiting for the eCheck to clear.
Old Mar 11, 2008 | 07:01 PM
FOMULA91's Avatar
Almost Spring break......
Old Mar 12, 2008 | 01:14 PM
FOMULA91's Avatar
Old Mar 14, 2008 | 12:12 PM
FOMULA91's Avatar
PM8 ECU Sold....
Old Mar 16, 2008 | 02:29 AM
FOMULA91's Avatar
123
