Tranny fluid
you grow a pair.....jk use your 3/8 inch drive breaker bar or remove the transmisson if it is really seized up and stand on wrench breaker bar whatever
Modified by twiztid17thninja at 8:22 PM 2/13/2008
I got mine off with my socket wrench (no socket attached), just stick the business end into square hole in the drain bolt. I then used a long piece of metal pipe to give me more leverage to break it free. Go to the Honda dealer and buy 3 quarts of Honda MTF. I've used 10w30 in the past also and it seemed to do fine.
3/8" rachet to remove drain bolt. Older Honda transmission call for an SF/SG grade 10W-30 engine oil, states that in the owners manual. You can use either, it doesn't really matter.
FourthGenHatch
14
Apr 15, 2003 11:18 AM
