Suspension & Brakes Theory, alignment, spring rates....
need to go lower on current setup. help?
Old Feb 12, 2008 | 06:34 PM
yc_dc4mar's Avatar
Default need to go lower on current setup. help?
pretty much my suspension is stock. all i got is sportlines on stock shocks. i thought i would at least get a finger gap in front and back but only back got that front got like 2. is there something i did wrong. i swear ive seen other tegs lower than this on sportlines and stock shocks
pretty much just want to know if i can do something besides cut the springs to lower it more. cant really afford a new set up now. and dont want to buy anything. if i cant do anything then i will just wait i guess.
Old Feb 12, 2008 | 09:52 PM
JDMDAEK's Avatar
Default Re: need to go lower on current setup. help? (yc_dc4mar)
you can always fab your shock so that that you can slip it farther down in the fork for the front. You have to grind on it a little.. but **** if your low on cash cut a coil or two off and maybe make some extended top hats and you will be low
jdmsupreme2132
Suspension & Brakes
23
Aug 30, 2009 10:32 PM
yc_dc4mar
Feb 12, 2008 10:13 PM
Ej896
Mar 22, 2007 11:58 PM
NAgixxer
25
Jun 18, 2004 02:19 PM
boostedsol
Jun 12, 2003 12:45 PM
