How many firewall delete plugs are there 92-95? Part #'s?
I need 3:
-- A/C lines (I know that one exists, just need the part #)
-- D series engine harness pass side (I believe I have seen a plug for this hole)
-- D series engine harness driver side
If anyone has the part #'s to the OEM grommets that would be great. I searched and found the one thread to an aftermarket $9 A/C grommet.
Thanks
Thanks
try looking it up on http://www.hondaautomotiveparts.com
Try this link instead. HondaPartsDeals.com has the largest images on their site, so it will be easier to see what is possibly available.
https://www.hondapartsdeals.co...3.gif
Then use any of the dealer sites to find the part numbers. Majestic Honda's site has list prices if you need an idea of the prices.
PLUG, HOLE
90852-671-003
LIST: $2.77
PLUG, VENTILATION HOLE (20MM)
90855-SA0-000
LIST: $3.37
15
GROMMET, WASHER HOSE
91617-SB6-000
LIST: $4.03
16
PLUG, AIR CONDITIONER HOLE
91631-SR3-000
LIST: $8.07
17
(Can't find this one under any hatch trim.)
19
PLUG, BLIND (10MM)
95550-10000
LIST: $1.73
20
PLUG, BLIND (12MM)
95550-12000
LIST: $0.47
23
PLUG, BLIND (25MM)
95550-25000
LIST: $2.77
PLUG, HOLE
90852-671-003
LIST: $2.77
90855-SA0-000
LIST: $3.37
15
91617-SB6-000
LIST: $4.03
16
91631-SR3-000
LIST: $8.07
17
19
PLUG, BLIND (10MM)
95550-10000
LIST: $1.73
20
PLUG, BLIND (12MM)
95550-12000
LIST: $0.47
23
PLUG, BLIND (25MM)
95550-25000
LIST: $2.77
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NOFX »</TD></TR><TR><TD CLASS="quote">Then use any of the dealer sites to find the part numbers. Majestic Honda's site has list prices if you need an idea of the prices.
PLUG, HOLE
90852-671-003
LIST: $2.77
90855-SA0-000
LIST: $3.37
15
91617-SB6-000
LIST: $4.03
16
91631-SR3-000
LIST: $8.07
17
19
PLUG, BLIND (10MM)
95550-10000
LIST: $1.73
20
PLUG, BLIND (12MM)
95550-12000
LIST: $0.47
23
PLUG, BLIND (25MM)
95550-25000
LIST: $2.77</TD></TR></TABLE>
Thanks a bunch
I'll find the part numbers and post them up
PLUG, HOLE
90852-671-003
LIST: $2.77
90855-SA0-000
LIST: $3.37
15
91617-SB6-000
LIST: $4.03
16
91631-SR3-000
LIST: $8.07
17
19
PLUG, BLIND (10MM)
95550-10000
LIST: $1.73
20
PLUG, BLIND (12MM)
95550-12000
LIST: $0.47
23
PLUG, BLIND (25MM)
95550-25000
Thanks a bunch
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Fuster_Cluck »</TD></TR><TR><TD CLASS="quote">Thanks a bunch
Those are the part numbers.
</TD></TR></TABLE>Those are the part numbers.
Those are the part numbers.</TD></TR></TABLE>
It was very early.....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Fuster_Cluck »</TD></TR><TR><TD CLASS="quote">Just placed an order for many of the plugs. Not much info for which ones work o the 92-95. I will let you guys know
They all work on the '92-'95. Those are all for 5th gens. All trims might not need them though.
</TD></TR></TABLE>They all work on the '92-'95. Those are all for 5th gens. All trims might not need them though.
That diagram doesn't have the delete plugs for the upper left & right holes in the firewall (headlight L&R harness maybe?) does anyone know the part numbers for 92-95 eg?
is one of the plugs pictured (in the hondapartsdeals diagram) a cruise control delete plug?
TeggieeTuner
Jan 28, 2013 04:17 PM
000, 90852671003, 90855sa0000, 91617, 91617sb6000, 95, civic, control, cruise, firewall, honda, integra, plug, plugs, sb6
