Compression Test
Old Feb 12, 2008 | 03:23 PM
lando griffin's Avatar
Default Compression Test
rented a compression tester from autozone today. did the test and all were in spec. but after cranking it and getting the final reading, the gauge would drop pressure...
is it a bad gauge or something else?
Modified by lando griffin at 7:16 PM 2/12/2008
Old Feb 12, 2008 | 06:38 PM
DOHCter's Avatar
Default Re: Compression Test (lando griffin)
if it doesn't hold pressure sounds like you have small valve seal leakage. But it still could be the rings, so the best thing to do is put a small amount of oil in the cylinder through the spark plug hold, half a cap full, and do the compression test again. the oil will seal the rings and if it still drops after holding the compression for a minute, then it is the valve seat, or seals. but if its holds strong, the its slow through the rings.
thats the ghetto mans version of a leak down, without actually having a separate leak down tester.
Old Feb 12, 2008 | 10:39 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DOHCter &raquo;</TD></TR><TR><TD CLASS="quote">if it doesn't hold pressure sounds like you have small valve seal leakage. But it still could be the rings, so the best thing to do is put a small amount of oil in the cylinder through the spark plug hold, half a cap full, and do the compression test again. the oil will seal the rings and if it still drops after holding the compression for a minute, then it is the valve seat, or seals. but if its holds strong, the its slow through the rings.
thats the ghetto mans version of a leak down, without actually having a separate leak down tester. </TD></TR></TABLE>
haha awesome thanks. i will try this again tomorrow.
zhan28
Feb 23, 2008 07:19 AM
Sport_Injected
Aug 16, 2004 09:06 PM
TypeR0186
Jul 21, 2004 07:40 PM
LSVTEC 91 Civic
Jun 22, 2004 11:30 PM
RedRacerCivic
11
May 22, 2003 10:29 AM
