so i have a 2005 rsx type s and want to do mods
Old Feb 12, 2008 | 02:39 PM
enoker001's Avatar
Default so i have a 2005 rsx type s and want to do mods
i want to get type r cams pistons and itr lsd helical but there for a k20a can i use those on my k20z1 and would i have to use higher octanine then 91
Old Feb 12, 2008 | 02:49 PM
NeWnMpR0VeD's Avatar
why would u wanna get type r cams when they are identical to the ones u have in the z1... and if so, i hope u know u cannot just swap cams and pistons and hope for it to net u the most gains just out the box without any sort of tuning.. and i'm sure u dont have to run higher than 91... 87 will be perfect LOL jk
Old Feb 12, 2008 | 02:55 PM
enoker001's Avatar
Default Re: (NeWnMpR0VeD)
thanks man yeah so the pistons and cams are the same as mine i thought they would be different
Old Feb 12, 2008 | 02:59 PM
Pat_S's Avatar
Default Re: so i have a 2005 rsx type s and want to do mods (enoker001)
1. Before you buy anymore DC5R parts, I want to tell you what the '05 RSX Type-S was already equipped with. It received DC5R camshafts, b-pipe and muffler from the exhaust, 4.77 final drive ratio, crankshaft pulley, and the intake snorkel duct.
2. It is possible to do that, but I think you'll barely notice any power gains whatsoever.
3. There is no need to use higher octane. You'll run fine with 91+.
Old Feb 12, 2008 | 03:08 PM
enoker001's Avatar
Default Re: so i have a 2005 rsx type s and want to do mods (Pat_S)
cool man thanks so i wanted to get a k24 block will that make a difference and just slap on the head i got whats cams should i go with
Old Feb 12, 2008 | 03:12 PM
Pat_S's Avatar
It will make a big difference, but you would have to do more than that to get it to run properly.
Search for more information. It's been covered so many times before.
Old Feb 12, 2008 | 03:28 PM
enoker001's Avatar
like internal work on the block where can i go read up on it
Old Feb 12, 2008 | 03:43 PM
Pat_S's Avatar
Use the search function. This here, shows you how it works.
Old Feb 12, 2008 | 03:49 PM
enoker001's Avatar
thanks man good looking out
Old Feb 12, 2008 | 08:28 PM
hondatuner020's Avatar
buy a cold air, race header and a cat back
after that make the drop on kpro.. best mod
dont forget about suspension
Old Feb 12, 2008 | 08:57 PM
yeah, i'd go for intake first... suspension 2nd... 3rd, possibly a decent header with esmm... and 4th, some better tires... u dont wanna go fast and lose control with those stock michellin tires... and last but not least, kpro... i had an intake header kpro setup on my 06 and i loved it... til i sold the kpro and missed it even more for a week.. then i got over it LOL
Old Feb 12, 2008 | 11:20 PM
PGHDC5's Avatar
trollin'... this dude aint gonna do **** with his engine.
Old Feb 13, 2008 | 06:15 AM
Pat_S's Avatar
Default Re: so i have a 2005 rsx type s and want to do mods (hondatuner020)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondatuner020 &raquo;</TD></TR><TR><TD CLASS="quote">buy a cold air, race header and a cat back
after that make the drop on kpro.. best mod</TD></TR></TABLE>
He'll be surprise what numbers it will put down, without a single problem.
Old Feb 13, 2008 | 11:24 AM
madchiller's Avatar
Premium Member
25 Year Member
Default Re: so i have a 2005 rsx type s and want to do mods (PGHDC5)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PGHDC5 &raquo;</TD></TR><TR><TD CLASS="quote">trollin'... this dude aint gonna do **** with his engine. </TD></TR></TABLE>
so true. lol!
Old Feb 13, 2008 | 12:27 PM
enoker001's Avatar
Default Re: so i have a 2005 rsx type s and want to do mods (chadismo)
i all ready have dc racing headers and the password jdm intake and straight pipe so now i guess all i need is k pro and i plan on buying a aem fuel rail with the fuel pressure regulator what cams will good in my car should i buy a different exhaust or keep my pipe straight
Modified by enoker001 at 2:06 PM 2/13/2008
Old Feb 13, 2008 | 07:00 PM
Pat_S's Avatar
Buy an exhaust and ditch the straight pipe. Oh, and it's header, not headers.
Old Feb 13, 2008 | 10:23 PM
portaman03's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by enoker001 &raquo;</TD></TR><TR><TD CLASS="quote">i all ready have dc racing headers and the password jdm intake and straight pipe so now i guess all i need is k pro and i plan on buying a aem fuel rail with the fuel pressure regulator what cams will good in my car should i buy a different exhaust or keep my pipe straight
Modified by enoker001 at 2:06 PM 2/13/2008</TD></TR></TABLE>
The next mod should be punctuation.
Old Feb 15, 2008 | 04:03 PM
Kidnkorner's Avatar
enoker001,
I suggest you get an RBC Intake manifold, 70mm BDL throttle body, a nice set of IPS cams with spings and retainers, a full exhaust system, a good high flow air induction system, and a good tune with Kpro.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Pat_S &raquo;</TD></TR><TR><TD CLASS="quote"> 3. There is no need to use higher octane. You'll run fine with 91+.</TD></TR></TABLE>
I really wish you would speak to an aquaintence of mine. He seems to think that the 100 octane fuel he is using is advancing his timing and he is gaining so much more power.
Old Feb 15, 2008 | 07:44 PM
thathondaguy's Avatar
Default Re: so i have a 2005 rsx type s and want to do mods (Kidnkorner)
I don't think the 2005 type s has a k20z1, that is the engine in the new SI isn't it? I'm sure it makes a dif. becuase they changed a few things and I know for a fact that kpro won't work on the new si engine, which I believe is the z1. Also I don't think I would put a k24 head on your k20. The k20 is more aggressive and is designed for the higher redline on the type s.
You should look into getting a new set of mounts to help with wheel-hop and spin, I recomend the innovative motors mounts. Kpro is the best upgrade, even with some of the maps hondata preloads you will see an amazing difference in performance.
John
Old Feb 15, 2008 | 08:03 PM
Pat_S's Avatar
Default Re: so i have a 2005 rsx type s and want to do mods (thathondaguy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thathondaguy &raquo;</TD></TR><TR><TD CLASS="quote">I don't think the 2005 type s has a k20z1, that is the engine in the new SI isn't it?</TD></TR></TABLE>
Wrong.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thathondaguy &raquo;</TD></TR><TR><TD CLASS="quote">I'm sure it makes a dif. becuase they changed a few things</TD></TR></TABLE>
They did change a few things such as DC5R camshafts, b-pipe and muffler from the exhaust, 4.77 final drive ratio, crankshaft pulley, and the intake snorkel duct which I've stated, but I highly doubt there would be a huge difference whatsoever.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thathondaguy &raquo;</TD></TR><TR><TD CLASS="quote">I know for a fact that kpro won't work on the new si engine, which I believe is the z1.</TD></TR></TABLE>
K-Pro will work on the '05-'06 RSX Type-S's k20z1. Please, do your homework.
Old Feb 15, 2008 | 09:27 PM
risktypeS's Avatar
the new si's is/are k20z3, variants of the k20z1. Also, you actually lose redline down to 7k (i believe) with the k24 frankenstein hybrid as oppossed to the 8.5+k with k20a2/z1.
Old Feb 16, 2008 | 05:53 AM
Kidnkorner's Avatar
Default Re: so i have a 2005 rsx type s and want to do mods (risktypeS)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by risktypeS &raquo;</TD></TR><TR><TD CLASS="quote">the new si's is/are k20z3, variants of the k20z1. </TD></TR></TABLE>
closer to a 2.0 version of the K24A2 actually. SCC magazine even says so in one of their articles on the new civic.
Old Feb 16, 2008 | 06:39 AM
sorry about that, I never really looked into the engine differences between 002-04 and 05+ becuase I have an 02. I thought they introduced the k20z with the new si.
I know kpro works with 05/06 type s but I also know that it doesn't work with new civic si's.
John
Old Feb 16, 2008 | 08:33 AM
Kidnkorner's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thathondaguy &raquo;</TD></TR><TR><TD CLASS="quote">I know kpro works with 05/06 type s but I also know that it doesn't work with new civic si's.
John</TD></TR></TABLE>
Yes Kpro is available for 05-06 RSX-S, a conversion harness is required and a 2002-2004 ECU. Kpro can be used on the 2006-2008 Civic Si but you have to convert the drive by wire to conventional throttle and rewire the car to eliminate MAF. The problem with this set up is that dash function is lost and one has to go with custom gaging. Some have speculated that the Si uses dash signals similar to the S2000, if this is the case one can use the various converters that are floating around for people going with S2000 clusters in their vehicles. HASport swapped a K20Z3 into a fit and they kept the DBW and to my knowledge the MAF too. They used KPro for the engine and the FIT ecu for A/C and dash function.
teamoptimum
Jul 30, 2006 08:26 AM
and1b0i
Nov 27, 2005 07:37 PM
SubTitle
24
Jun 6, 2004 08:55 PM
Wattup Though 00
May 2, 2004 07:34 PM
ak1ra07
Dec 3, 2003 07:25 AM
