Turbo RSX Questions
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by protec77 »</TD></TR><TR><TD CLASS="quote">Should i run a AVCR or should i do a hondata celinoid for my boost control? </TD></TR></TABLE>
Really depends on if you can find someone to dial in the AVCR properly. The hardest part is that. I personally went with a Perrin solenoid and Kpro boost control. Cant beat a 100 dollar boost by gear controller.
Built and sleeved. If you can get the AVC-R dialed in and actually make use of the gain capabilities go for it. If not them you are paying 400 bucks for a boost by gear controller where you could have paid 100.
WOW im gonna be on a stock block with head studs head gasket rbc stage 5 clutch!!! how much power u think i can make with a pt61 precision turbo!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by protec77 »</TD></TR><TR><TD CLASS="quote">WOW im gonna be on a stock block with head studs head gasket rbc stage 5 clutch!!! how much power u think i can make with a pt61 precision turbo!</TD></TR></TABLE>
Really depends on turbo manifold, exhaust, IC and IC piping setup but you should make 400-450 easily on pump gas. I wouldnt take it past that on a stock block unless you throw in some race gas and shoot for more power but eventually it will go.
ONE*SICK*FERIO
Jun 26, 2008 01:46 PM
