Hondata
Im curious, does hondata have any effect on getting your car inspected, I remember they checked the ecu or somethin for the O2 sensor, so would hondata mess with that, or cause you to fail inspection or something?
If you have an 01-03 then you need to move the primary O2 sensor input to the secondary so it reads it. There is a box you can click to enable readyness codes and it'll spit out data to the scan port, but i dont know of anyone who's tried hooking it up to a DMV scanner. better bet would be to get an 04-05 wideband, and rewire the primary O2 sensor into its own harness and add it into the ECU pinout.
Thanks for all the input. Im still saving for Kpro, so I have a while before I need to know for sure. Anyone in Texas with Hondata have any problems passing inspection?
ih8speedbumps
Engine Management and Tuning
Apr 8, 2014 10:39 AM
jadugartir
Dec 13, 2006 10:53 PM
