jdm zc intake mani vs usdm mani
Old Feb 12, 2008 | 01:07 PM
ejcivicex's Avatar
Default jdm zc intake mani vs usdm mani
i ordered from hmotors and i am curious on why i have to change the manifold is it for the emissions or with the motor not run right?? i am not worried about emissions just want the motor to run proper so if i put the jdm zc engine in without swapping intake manifolds will the engine not run properly i understand that i will probably have to switch the throttle bodies due to sensors but would i have to change the whole manifold to my y8 manifold or can i leave the jdm zc on .
Old Feb 12, 2008 | 01:27 PM
crazyguy's Avatar
Default Re: jdm zc intake mani vs usdm mani (ejcivicex)
i think all d series intake manifold are the same .except some has map sensor on the firewall and some on the TB. i have a jdm b16a engine and i am running a usdm itr intake manifold.
Old Feb 12, 2008 | 01:41 PM
ejcivicex's Avatar
Default Re: jdm zc intake mani vs usdm mani (crazyguy)
but could i run the jdm zc manifold>?
Old Feb 12, 2008 | 06:42 PM
ejcivicex's Avatar
any one
Old Feb 12, 2008 | 07:22 PM
ejoner's Avatar
The difference is the purge solenoid mount and the vacuum nipple for the purge solenoid. You can still use the jdm manifold and just make a bracket for the purge solenoid some were else or zip tie it out the way and just use a "T" tap from another vacuum source to supply it.
Old Feb 13, 2008 | 11:22 AM
ejcivicex's Avatar
what does this purge solenoid look like ? and where is it located thanks for the info
Mr. Winky
Sep 7, 2008 11:26 AM
skate1968
Feb 23, 2008 07:24 AM
EFsideways
Dec 1, 2007 04:01 PM
HXMan
Dec 13, 2001 11:02 PM
