05 RSX rpm cutting off at 5k - Help
Old Feb 12, 2008 | 10:53 AM
SinsEvil666's Avatar
Default 05 RSX rpm cutting off at 5k - Help
Friends RSX was runnign great, and now the rpm is cutting off at 5k. what can the problem be? we have no clue, car still running perfectly smoothe besides the rpm cutting off at exactly 5k. Help Greatly appreciated. Thank You.
Old Feb 12, 2008 | 10:55 AM
blueshark123's Avatar
Default Re: 05 RSX rpm cutting off at 5k - Help (SinsEvil666)
What are the mods and is there a check engine light on?
Old Feb 12, 2008 | 11:00 AM
Type S,has Header, Intake, and ECU is chipped other than that car is stock....and yes, engine light is on
Modified by SinsEvil666 at 1:26 PM 2/12/2008
Old Feb 12, 2008 | 12:11 PM
Default Re: (SinsEvil666)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SinsEvil666 &raquo;</TD></TR><TR><TD CLASS="quote">Type S has Headers, Intake, and ECU is chipped other than that car is stock....and yes, engine light is on</TD></TR></TABLE>
The k20 has a header not headers. What "chip" is in the ECU? If it's Kpro hook up a laptop and check the code.
Old Feb 12, 2008 | 01:32 PM
Pat_S's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SinsEvil666 &raquo;</TD></TR><TR><TD CLASS="quote">Friends RSX was runnign great, and now the rpm is cutting off at 5k. what can the problem be? we have no clue, car still running perfectly smoothe besides the rpm cutting off at exactly 5k. Help Greatly appreciated. Thank You.</TD></TR></TABLE>
I'm assuming only when in neutral?
Old Feb 12, 2008 | 01:37 PM
risktypeS's Avatar
If it has K-pro check to see if cutoff was accidently set to 5k.
Old Feb 12, 2008 | 02:01 PM
SkankyEJ7's Avatar
Default Re: 05 RSX rpm cutting off at 5k - Help (Pat_S)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Pat_S &raquo;</TD></TR><TR><TD CLASS="quote">
I'm assuming only when in neutral?</TD></TR></TABLE>
yeah thats what it should be in neutral. plus i think the limp mode limiter is lower than that too
Old Feb 12, 2008 | 02:32 PM
Pat_S's Avatar
Default Re: 05 RSX rpm cutting off at 5k - Help (SkankyEJ7)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SkankyEJ7 &raquo;</TD></TR><TR><TD CLASS="quote">
yeah thats what it should be in neutral. plus i think the limp mode limiter is lower than that too</TD></TR></TABLE>
Correct, it should be like that only when in neutral. It won't go pass 5,000 rpm.
That's for the '05-'06's, don't know if it applies to the '02-'04's.
Old Feb 13, 2008 | 12:11 PM
That's for the '05-'06's, don't know if it applies to the '02-'04's.</TD></TR></TABLE>
OK, i guess there is no problem at all since its normal cause he does have the 05, Thank you all for the help and letting me know its normal....else could of driven us nuts trying to figure out a problem that dont exist
Old Feb 13, 2008 | 02:28 PM
Pat_S's Avatar
OK, i guess there is no problem at all since its normal cause he does have the 05, Thank you all for the help and letting me know its normal....else could of driven us nuts trying to figure out a problem that dont exist</TD></TR></TABLE>
It sort of reacts like a two step in a way. It's completely normal.
Edit: PM'd.
Ange Dechu
27
Mar 26, 2008 07:19 AM
AznInvasion
Mar 22, 2008 09:56 AM
GsrIntegra789
Feb 11, 2008 11:00 AM
nudo_typeR
Dec 2, 2003 01:41 AM
swlabhot
Nov 4, 2003 08:29 PM
