__**** Skunk2 Mega Power Exhaust Cat-Back ****__
Old Feb 12, 2008 | 10:34 AM
zammitjon's Avatar
Default __**** Skunk2 Mega Power Exhaust Cat-Back ****__
I bought a (Skunk2 Mega Power Exhaust Code: 413-05-1530) for an Integra Type R year 2000.
Can anyone help me?
Why is the exhaust made in Taiwan?
The diameter of the tip is Not 110mm but 100mm!
The piping is less than 60mm in diameter!
The biggest problem I have is that the exhaust is around 150mm short to the catalytic converter.....so I cannot even install it!
Is in it suposed to fit directly, or i need to buy some sort of an extension?
Thanks.
Old Feb 12, 2008 | 10:42 AM
jomama's Avatar
geeesh, are you sure it's the real thing? is it a different model or for a different car? you could just install a test pipe or any sort of extension. good luck.
Old Feb 12, 2008 | 10:48 AM
zammitjon's Avatar
Default Re: (jomama)
Well...i bought the Item from Tunerz Image Inc. CA, an authorised dealer of Skunk2!
I just wanted to know if it should actually direct fit?
Thanks.
Old Feb 12, 2008 | 10:52 AM
cmdr430's Avatar
Default Re: __**** Skunk2 Mega Power Exhaust Cat-Back ****__ (zammitjon)
Is your car U.S. spec(I doubt it) or Euro spec or JDM spec?
That is where your problem lies, would be my bet....
Old Feb 12, 2008 | 10:53 AM
zammitjon's Avatar
Default Re: __**** Skunk2 Mega Power Exhaust Cat-Back ****__ (cmdr430)
JDM Spec.
Old Feb 12, 2008 | 12:12 PM
GUILOTINE's Avatar
Kill Gil
The exhaust is designed for use a USDM cat lenght. It sounds like you didn't recieve the correct exhaust if it is not 70mm in diameter on the piping.
Old Feb 12, 2008 | 12:49 PM
zammitjon's Avatar
Default Re: __**** Skunk2 Mega Power Exhaust Cat-Back ****__ (GUILOTINE)
Well.... on Skunk2 website it states that the 70mm which is Mega Power R is not produced for Integra Type R. Only the 60mm one which is Mega Power is produced for Integra Type R!!
Before i bought the item, i asked the dealer if it fitted a JDM spec, and he said yes!!!
Old Feb 12, 2008 | 12:53 PM
GUILOTINE's Avatar
Kill Gil
It will fit, all you have to do is extend the cat or make a custom test pipe
Old Feb 12, 2008 | 12:55 PM
zammitjon's Avatar
actually, that is what i was thinking of doing! I just want to be sure that i received the proper item and that the piping is slightly bigger for better performance!!
Old Feb 23, 2008 | 04:00 AM
team1320_k26eg's Avatar
hope it works out for you.
Old Feb 23, 2008 | 04:08 AM
RTW DC2R's Avatar
next time I have a problem with my car, Im gonna call up my accountant to see if he can help. call the place you bought it from!
Old Feb 23, 2008 | 12:19 PM
Henryx33's Avatar
Default Re: (RTW DC2R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zammitjon &raquo;</TD></TR><TR><TD CLASS="quote">
Everything is made in Taiwan. lol
Hermstick
Honda Civic (2006 - 2015)
13
Apr 18, 2010 01:35 PM
iverson3yoo
Jan 3, 2007 10:49 PM
SexyAzNMami
44
Dec 12, 2004 12:19 PM
Pretegra
Jun 8, 2004 06:33 PM
