HELP!! Surging idle on 2000 Accord 4cyl
Old Feb 12, 2008 | 10:06 AM
vtectommyd's Avatar
Default HELP!! Surging idle on 2000 Accord 4cyl
Hopefully someone here can help.
Just did the egr port cleaning on my gf's ' 2000 accord 4cyl(it ran fine but threw a cel for it)
so i cleaned it and while everythign was apart i also cleaned the intake manifold, throttle body, and the idle control valve.
put it together with all new gaskets and now the idle surges(1000-2200), i quadruple checked that i had everything hooked back up right and am confident it all is including vacuum lines.
i tried bleeding the cooling system like 3 times from the bleeder on the water neck right below the tb and the hose that runs to the tb(the one conecction on this hose is like the highest point of the cooling system)
also sprayed brake clean everywhere i worked thinking maybe there was a leak somewhere
am i mssing something? or should i try checking the idle control valve again? try bleeding the cooling system again?
nrmskate
Sep 10, 2013 08:28 AM
J.B.Motorwerks2
Aug 10, 2013 05:29 PM
mikeycivic
Jun 7, 2012 12:09 PM
joshua89
Aug 20, 2011 01:47 PM
Badewolf
Mar 12, 2011 05:53 PM
