01 civc ex want to convert to 02 si cluster
I'm going to be attempting to swap the ep3 type R cluster this spring. I've actually had the gauge cluster for over 4 years now but never got around to attempting it.
The plugs fit but you need to re-pin the plugs to match the ep3 cluster.
Toyomatt84 is right. The cluster doesn't fit properly in the em2/es1/es2 gauge housing. You will need to do some modifications to make it fit.
I know for sure that you will need to cut off the top tab off the ep3 cluster.
crooked muffler
Feb 24, 2005 06:08 PM
