No Signal to ECU
92 Accord EX Sedan 5spd F22A6
OK my ecu fuse under the hood keeps blowing.
Ive swapped three different ecu's (ecu is good)
checked all power sources to ecu (neither of the two yel/black are getting power)
Main relay isnt getting power
Swapped three different main relay's same issue
Ive jumped the main relay harness and can manually get power to the fuel pump and injectors (seemingly fine)
Ive located where each yel/black wire come together and power the injectors,ecu,IAC valve and O2
Ive tested each of these individually with a fused link and supplied power to each and all of them pass.
On two different occasions Ive gotten my car to run but the problems only goes away for about a week or so, its an intermittent problem and I cant track it down.
ANY HELP PLEASE I'M SO STUMPED. IVE GOT A HELMES WIRING SCHEMATICS. AND THE DEALER CANT EVEN TELL ME ANYTHING.
PLEASE ANY EXPERTS OR FOLKS WITH SAME EXPERIENCE?
Modified by lowcomet at 1:52 AM 2/13/2008
AndyDaSilva
Jun 27, 2015 09:01 AM
LS_DON4500
Mar 31, 2006 07:56 PM
