07 Accord headunit install and 6 1/2 components
Old Feb 12, 2008 | 07:26 AM
loki2323's Avatar
Default 07 Accord headunit install and 6 1/2 components
Two quick questions for an install on a 2007 Accord
1) Aftermarket headunit- Can the stock head unit be removed? The only install kits I found were relocation kits?
2) To install a 6 1/2 component system in the car do I need adapters for the speakers to fit?
Thanks
Old Feb 13, 2008 | 06:12 AM
loki2323's Avatar
Default Re: 07 Accord headunit install and 6 1/2 components (loki2323)
Anyone?
Well I found this:
http://www.crutchfieldcanada.c...4.htm
Seems a little pricey just to keep my cubby that is at the bottom.
Modified by loki2323 at 4:34 PM 2/13/2008
Old Feb 13, 2008 | 06:14 PM
chrisw85's Avatar
You may be better off using a device like the JL Audio CleanSweep, that metra dash kit is hit or miss (usually miss) for the new accords.
I'd rather make a custom cutout on the stock piece and perhaps pac-swi makes something that could be used/modofied so you could still retain all your factory buttons on the wheel and have a double-din or single din HU installed. But some people like the metra one after some modifications...
Old Feb 13, 2008 | 06:37 PM
loki2323's Avatar
Default Re: (chrisw85)
I'm thinking I might just get the kit that fits in the bottom cubby hole. It's cheaper and I won't have to mess with custom fitting anything. I read up more on the metra one and people were saying it's not made well and some were using the stock ***** because the aftermarket ones didn't light up the same.
screech527
Jul 8, 2008 10:18 PM
RI_TM
Audio / Security / Video
Feb 15, 2008 01:12 PM
pentosinjunky
Feb 16, 2006 08:46 AM
Haccord182
Mar 4, 2004 10:17 PM
