Will EK or Integra Springs/Shocks work in an EG?
Old Feb 12, 2008 | 06:25 AM
jimjackson's Avatar
Default Will EK or Integra Springs/Shocks work in an EG?
I tried searching but couldn't find a definite answer. Some said it will work other said it won't, while some said only the fronts work but not the rears...
So my question is, will 94+ Integra or EK springs/shocks front and rear work in an EG?
Thanks!
Old Feb 12, 2008 | 06:27 AM
slo_hatch's Avatar
Default Re: Will EK or Integra Springs/Shocks work in an EG? (jimjackson)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jimjackson &raquo;</TD></TR><TR><TD CLASS="quote">I tried searching but couldn't find a definite answer. Some said it will work other said it won't, while some said only the fronts work but not the rears...
Thanks! </TD></TR></TABLE>
i have heard that integra rears will work but you will have to cut one coil off of the front...thats just what i heard. not real sure. why not just buy them for an eg?
Old Feb 12, 2008 | 06:37 AM
kiddcarbuff's Avatar
i had integra springs on my eg, worked fine. jsut stiffer
Old Feb 12, 2008 | 06:39 AM
slo_hatch's Avatar
Default Re: (kiddcarbuff)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kiddcarbuff &raquo;</TD></TR><TR><TD CLASS="quote">i had integra springs on my eg, worked fine. jsut stiffer</TD></TR></TABLE>
did you have to cut the front one? i was gonna buy some used neuspeeds from someone to put on my eg but the springs came off an integra. they said to cut the front springs down by one coil and they would work fine. so idk...i just bought tein s.techs. lol
Old Feb 12, 2008 | 06:48 AM
jimjackson's Avatar
Default Re: Will EK or Integra Springs/Shocks work in an EG? (slo_hatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slo_hatch &raquo;</TD></TR><TR><TD CLASS="quote">
i have heard that integra rears will work but you will have to cut one coil off of the front...thats just what i heard. not real sure. why not just buy them for an eg?</TD></TR></TABLE>
Its easier and cheaper finding EK and integra parts and I'd really like to get a GSR suspension if it will work.
What about the shocks, do they swap out also?
Old Feb 12, 2008 | 06:51 AM
slo_hatch's Avatar
oh ok..and that part im not sure about. so your tryin to do the full gsr suspension? lol j/w...why not go type-r suspension?
Old Feb 12, 2008 | 06:53 AM
ej1love's Avatar
when i got my tokicos they said it would work on 92-00 civic or 94-01 integra. I put them on a ej1. U should be straight.
Old Feb 12, 2008 | 10:16 AM
blk92_d16's Avatar
When I bought my used '92 hatch, I was told he had put his EK struts in it for me. Besides that, I wouldn't know...
Old Feb 12, 2008 | 12:06 PM
slammed00si's Avatar
Default Re: (blk92_d16)
they will work and no you dont have to cut a coil. i ran itr springs in my eg and now run an ek type flex coil over setup. the only part that needed to be modified to run the ek on the eg was the rear control arm bushing that had to be shaved. other then that its just a bolt up job.
Old Feb 12, 2008 | 12:16 PM
PHDM-EK's Avatar
EK and Integra Springs/Shocks will work on EG's but EK rear shocks won't work because EK Rears are fork-type shocks.
Old Feb 12, 2008 | 01:20 PM
Default Re: (PHDM-EK)
they will work i have them on my car. eg's are fork type rear, the only difference is the width of the lower control arm bushing. only type r had the different setup rear shocks.
Old Feb 12, 2008 | 06:15 PM
[QUOTE=jimjackson]
What about the shocks, do they swap out also?[/QUOTEi had agx for my eg originaoly and swapped them for illuminas for an integra later as well. i didnt cut any coils, they acutally dropped my car more. you dont need to cut **** eg/dc stuff is all compatiable. as for the ek, the socks will fit and they ARE fork type shocks. to fit on the lca tho the lca bushing must be ground down abou 5mm on each side
Old Feb 13, 2008 | 07:51 AM
jimjackson's Avatar
Awesome guys, thanks for all the input. Looks like my best option would be to go with Integra stuff, since that requires no modification.
efnoobie
Dec 16, 2008 07:00 AM
Dupes
Aug 22, 2005 07:42 PM
The Destroyer
Aug 5, 2005 08:51 PM
tweedersc07
Mar 29, 2004 12:57 AM
turbod16y8
Oct 17, 2003 06:41 AM
