JDM ITR 5lug question
My friend in Dallas bought a 5lug conversion from JDMhondaparts.com a few months back. He got it in literally 4-5 working days. Not bad considering in came in truck from Southern California.
Down to the point. He is putting the front hub assembly on and is finding out his axles dont fit. The axle is too small. Fowler has suggested that he got some JDM axles because the JDM ITR run 16" wheels. Which is ALL understandable.
Where can I source JDM ITR axles or what kind of axles does my friend need to complete this conversion? Thanks in advance.
--Migs
--Migs
so is it due to the 98+ model year changes that the 5 lug hub was redesigned or is it because of 16" rims? i'm guessing the first. in any case, i'm really surprised by this incompatibility. can someone else confirm this?
MiGs, what kind of Teg does your friend have? GS-R, GS, LS, or RS?
from what I remember u can use prelude on the hub side and integra inner...axle building time..
I learned from SgT that 98+ JDm ITR Hugs are based on the Prelude Outers. This makes them stronger where they stock axles normally break. It actually would be a good swap, using the Prelude Outers because they are so much stronger.
yes 36mm axles are specific to Preludes, Accords and CRVs.....
either get JDM 98-01 SpecR (ITR) axles or outers from Preludes or CRVs
CTR is identical to USDM ITR so problems there, standard 32mm nut, and axle
Is there any point to converting to 5 lug besides looks? just curious...
chapagetti
Jun 23, 2009 08:52 AM
l2p
Jun 11, 2004 07:27 AM
