oil leak
i am guessing that oil leaks happen, but i am frustraded a little.
I replaced the valve gasket, since oil streaks very in the area of the gasket. But now i turns out that oil is still comming from a little below. it look like its leaking in the right back corner below the valve gasket. unfortunatly i can not see from where it is really comming, but it is evidently building up an dripping down.
has anyone a guess, what might be cause? do i better get it served at a shop or can i do it myself?
thanks for any help.
Open the hood or the drivers door and look for a sticker that tells you
WHAT YEAR your Accord is.
Get a spray can of brake clean and then blast down the area where you suspect the leak is, then go for a short drive and recheck the area.
HINT: an old plumber I know told me that liquid will usually run downhill.
dtorreskater
Honda Civic (2006 - 2015)
Sep 20, 2007 09:50 AM
