98 Rear Drum Brakes: Fluid or grease leak?
Old Feb 11, 2008 | 05:10 PM
petec's Avatar
Default 98 Rear Drum Brakes: Fluid or grease leak?
I just took the rear drums off my new (to me) 98 accord w 130,000 miles.
One drum had what looked like grease everywhere. Is it possible for the hub to leak grease, or is what I am seeing is brake fluid that looks "congealed". If the hub is leaking grease then I need to get a new hub for this side.
The other brake drum assembly was clean (other than brake dust), but the hub did not rotate smoothly at all. Do I need to get a new hub for this side?
Old Feb 11, 2008 | 06:27 PM
hondadude's Avatar
Default Re: 98 Rear Drum Brakes: Fluid or grease leak? (petec)
I doubt there is grease leaking into the hub, more often the slave cylinder is the problem.
Peel back the rubber boot and see if brake fluid comes out.
On the other side where you say the hub doesn't turn smooth.
If the drum is warped [out of round] it will grab and let go when you turn it by hand.
Most parts stores will turn the drums pretty cheap.
A driving test for warped drums is to get on the highway around 50 mph and lightly pull up the parking brake and feel the vibration
Old Feb 12, 2008 | 03:35 PM
petec's Avatar
Default Re: 98 Rear Drum Brakes: Fluid or grease leak? (hondadude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondadude &raquo;</TD></TR><TR><TD CLASS="quote">
The hub does not rotate smoothly with the drum removed.
globy123
Sep 21, 2009 01:07 PM
globy123
Sep 21, 2009 11:56 AM
Offer
Oct 23, 2006 06:41 PM
89sicivic
Mar 2, 2006 10:01 AM
