h22 pistons?
Old Feb 11, 2008 | 04:06 PM
slowassBubble's Avatar
Default h22 pistons?
i have a 97 h22a in my car(93 civic) anyways i need piston, were car i purshace these the cheapeast, am not lookin for perfomace i just need my car running, how much should i be paying...also do f22 acord pistons work?
Old Feb 11, 2008 | 04:12 PM
Apex1972's Avatar
Default Re: h22 pistons? (slowassBubble)
Only H22A4 pistons will work. If you are trying to get out as cheap as possible.
Old Feb 11, 2008 | 06:27 PM
98vtec's Avatar
moderator emeritus
Default Re: h22 pistons? (Apex1972)
unless you want to have the rods rebushed to run a floating wrist pin then you can either use h22a4 pistons and type S h22 pistons. The type S will raise your compression to 11:1.
you can purchase the pistons and rings through an online honda wholesale dealer.
Old Feb 11, 2008 | 07:29 PM
bluedlude's Avatar
out of curiosity, what was wrong with the engine that you just need to replace the pistons?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98vtec &raquo;</TD></TR><TR><TD CLASS="quote">unless you want to have the rods rebushed to run a floating wrist pin then you can either use h22a4 pistons and type S h22 pistons. The type S will raise your compression to 11:1.
you can purchase the pistons and rings through an online honda wholesale dealer.</TD></TR></TABLE>
does the JDM H22a only have semi floating wrist pins? i know h22a4 rods are full floating and have .866 wrist pins and type S pistons have .864 wrist pins and require a different rod with a smaller small end diameter. now im sure you can hone the typeS pistons .002" to accept a h22a4 wrist pin, but you cant really use a typeS wrist pin on the h22a4 rod and get the right clearance. i unfortunately have a set of typeS pistons and pins and h22a4 rods . luckily i have a good machinist
Old Feb 11, 2008 | 07:31 PM
98vtec's Avatar
moderator emeritus
Default Re: h22 pistons? (bluedlude)
97 and h22a confused me i guess
Old Feb 12, 2008 | 02:29 AM
Default Re: h22 pistons? (98vtec)
am sorry its NOT a jdm model i forgot the rest of the engine code....the problem that i have is that i have play were the piston connects to the rod, the play is at the piston...yeah i know wierd but thats what 3 mechanics have told me it sounds like a knocking soud......anyway someone mentioned a honda wholesale dealer? is the a website or sumthing? thanks
Old Feb 12, 2008 | 04:25 AM
bluedlude's Avatar
hondaautomotiveparts.com, thats what i use and they always seem to have the best prices
H2b-eghatch
Oct 6, 2010 07:40 PM
adam94lude
Oct 12, 2005 07:25 PM
EM2Civic
Feb 27, 2005 05:01 PM
H22A_HB
Sep 3, 2004 08:43 PM
