Suspension & Brakes Theory, alignment, spring rates....
crx darts on uneven ground
Old Feb 11, 2008 | 03:02 PM
pdx_503's Avatar
Default crx darts on uneven ground
I know a lot of you guys experienced your car darting side to side on uneven pavement. Its pretty annoying when you have to drive with two hands and white-knuckle it to try and keep it staight. What is the cause of this?
Old Feb 11, 2008 | 03:22 PM
pdx_503's Avatar
Default Re: crx darts on uneven ground (pdx_503)
Nothing?
Old Feb 11, 2008 | 03:47 PM
Tyson's Avatar
alignment probably.
Old Feb 14, 2008 | 12:55 PM
hades's Avatar
too much static toe out, bad cords in tires, loose tie rods, worn flca bushings (the last two cause dynamic toe-out so the toe may not look bad sitting there, but gets bad as you put stress on the suspension)
Old Feb 14, 2008 | 06:22 PM
Targa250R's Avatar
be professional
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pdx_503 &raquo;</TD></TR><TR><TD CLASS="quote">I know a lot of you guys experienced your car darting side to side on uneven pavement. Its pretty annoying when you have to drive with two hands and white-knuckle it to try and keep it staight. What is the cause of this?</TD></TR></TABLE>
Poor alignment, bad tires, uneven pressures, improperly-sized wheels and tires, bad bushings.
When was the last time you had the car on an alignment rack? Tire and wheel size and offset?
Old Feb 15, 2008 | 06:00 AM
CRX Lee's Avatar
Default Re: crx darts on uneven ground (Targa250R)
As above, check your front toe setting. Either the adjustment or worn parts.
Old Feb 16, 2008 | 08:01 PM
El_Capitan's Avatar
It's just I-5 bro....
Old Feb 16, 2008 | 09:19 PM
johnlear's Avatar
Banned
Default Re: crx darts on uneven ground (El_Capitan)
All the above comments are relevant and possible causes. It could also be caused by tyres that are very wide and / or with a very low profile, especially at higher psi. Have you recently made any changes that might possibly have caused this (tyres, suspension etc), or is it a long standing problem? More info...
Old Feb 17, 2008 | 08:41 PM
elwuudz2's Avatar
Alignment, tire pressure, uneven shock valving, or unbalanced wheel-tire combo, even ride height and rake sometimes
But... most likely the alignment, just realize you'll become a better driver having to compensate for your suspension changes until you get an alignment.
Be careful and don't let it go too long or you'll unevenly wear your tires
Old Feb 18, 2008 | 03:16 AM
Targa250R's Avatar
be professional
Default Re: crx darts on uneven ground (elwuudz2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by elwuudz2 &raquo;</TD></TR><TR><TD CLASS="quote">just realize you'll become a better driver having to compensate for your suspension changes until you get an alignment.</TD></TR></TABLE>
What
Nobody is going to "become a better driver" by driving around with a bad alignment.
nanagsr
Aug 20, 2009 12:34 PM
kasperxtcy
Suspension & Brakes
Mar 31, 2007 11:30 PM
EK FLY
Mar 29, 2006 04:08 PM
CRX_Type_R
40
Feb 25, 2005 06:46 PM
jrv2u
Dec 1, 2004 10:06 PM
