reason for idle problem?
Old Feb 11, 2008 | 03:00 PM
cleanej2's Avatar
Default reason for idle problem?
i just installed an intake manifold on my d15b7 and everything was fine at first and then it started to idle funny, most of the time it will do it but sometimes it wont.. it jumps up and down about 500 rpms. im guessing its an air leak somewhere but i cant find one. any suggestions on what it might be?
Old Feb 11, 2008 | 03:03 PM
SiKnezzX408's Avatar
Default Re: reason for idle problem? (cleanej2)
either air in the coolant. or your iac
Old Feb 11, 2008 | 03:04 PM
Brick Top's Avatar
go over all the bolts again. and the nuts holding the manifold on
Old Feb 11, 2008 | 03:07 PM
Default Re: reason for idle problem? (Brick Top)
If you have a leak in the intake, your motor would be reving high up there. It should fluctuate, meaning air bubbles in the cooling system, or IACV
cleanej2's Avatar
Default Re: reason for idle problem? (SiKnezzX408)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SiKnezzX408 &raquo;</TD></TR><TR><TD CLASS="quote">either air in the coolant. or your iac
i know i need a new radiator cap cuz the seal on mine rotted and broke off.. im guessing thats the problem then?
Old Feb 11, 2008 | 03:10 PM
suspendedHatch's Avatar
No, that wouldn't cause the problem. You could have no radiator cap on and it would idle fine. Bleed the coolant. The most basic way is to take off the radiator cap when the engine is cold, then start the car and let it run until it's fully warmed up (fan has come on twice).
Old Feb 11, 2008 | 03:14 PM
cleanej2's Avatar
Default Re: reason for idle problem? (suspendedHatch)
how will i know when the line is completely done bleeding?
Old Feb 11, 2008 | 04:27 PM
cleanej2's Avatar
Old Feb 12, 2008 | 11:00 AM
cleanej2's Avatar
anyone?
Old Feb 12, 2008 | 12:12 PM
you'll know it's done when the fan comes on twice! just like what suspendedHatch said.
Old Feb 12, 2008 | 12:58 PM
cleanej2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SiKnezzX408 &raquo;</TD></TR><TR><TD CLASS="quote">you'll know it's done when the fan comes on twice! just like what suspendedHatch said.</TD></TR></TABLE>
i thought he meant thats when the engine will be fully warmed up.. i didnt know that was for the coolant
Old Feb 12, 2008 | 01:02 PM
aznboyhoy's Avatar
try to adjust the throttle.
Old Feb 13, 2008 | 04:14 PM
cleanej2's Avatar
Default Re: reason for idle problem? (aznboyhoy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aznboyhoy &raquo;</TD></TR><TR><TD CLASS="quote">try to adjust the throttle.</TD></TR></TABLE>
wat does this have to do with the idle
Old Feb 13, 2008 | 07:50 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cleanej2 &raquo;</TD></TR><TR><TD CLASS="quote">
i thought he meant thats when the engine will be fully warmed up.. i didnt know that was for the coolant</TD></TR></TABLE>
yup.. the thermostat reaches certain temperature opening the thermostat, and thats when the fan comes on, pushing out air bubbles in the cooling system, when the cap is open. thats when you'll start to see coolant slowly flowing out when fan turns on.
Skyhigh07
Jan 15, 2009 11:48 AM
VTECchris
Nov 7, 2008 11:20 PM
13link EG
Oct 20, 2004 07:37 PM
CivicHatchback14
May 16, 2004 10:12 PM
fred92htch
May 10, 2003 07:11 PM
