Wich bearings!!
Old Feb 11, 2008 | 01:05 PM
amadriga's Avatar
Default What bearings!!??
Hello
I know there are ACL bearings for b17a, but I see that b18a/b bearings are the same that b17a so my question is:
Can I use b16a (rod and main) bearings in a b17a engine?
Thanks.
Modified by amadriga at 2:30 PM 2/11/2008
Old Feb 11, 2008 | 05:26 PM
slowteg97's Avatar
Default Re: What bearings!!?? (amadriga)
just get the ones that go for the 1.7 dont wanna mess around whe it comes to that stuff or if you still have your old ones take them to acura and order the colors you need and hopefully remember where which color bearing went. if you wipe the side of the bearing you should see it marked red yellow green and so on
Old Feb 11, 2008 | 06:09 PM
ekb16's Avatar
most of the time the color on the bearing will wear off after its been in a running engine so takin it to the dealership might not be helpful...find the codes on the block,crank, rods and match them up and buy them from the dealership
Old Feb 12, 2008 | 04:27 AM
amadriga's Avatar
Thanks!!
Is there any online site that I can use to order bearings?
What about B17a ACL race bearings, what do you think, is it preferable to go with the OEM color coded bearings?
TurboKneeGrow
Mar 18, 2008 07:22 PM
yaoming315
Jul 21, 2007 11:46 PM
marcussmith26
Jan 17, 2006 02:45 PM
haysr
12
Jul 31, 2005 09:39 AM
