Will the LSD in my M2B4 swap on to my new M2A4?
Old Feb 11, 2008 | 12:55 PM
WRXnomore's Avatar
Default Will the LSD in my M2B4 swap on to my new M2A4?
M2B4 missing 2nd and 5th, bought M2A4 as replacement because I could not find another M2B4 in good shape. Seeing as how my LSD is fine, can I swap it to the M2A4? (5th gen. H22a4 manual swap)
Old Feb 12, 2008 | 08:41 AM
redline7's Avatar
Default Re: Will the LSD in my M2B4 swap on to my new M2A4? (WRXnomore)
Bump cuz my lsd tranny is starting to grind 5th...
Old Feb 12, 2008 | 09:03 AM
98vtec's Avatar
moderator emeritus
i want to say no. But i really cant give you 100% answer. I know this has been answered before so try searching this forum in recent and archived threads.
Old Feb 12, 2008 | 09:39 AM
dartonh22's Avatar
Default Re: Will the LSD in my M2B4 swap on to my new M2A4? (98vtec)
i have been told it can be done, i am haveing the same issue with my h23 trans and i have a broke m2b4 trans, and i wanted to switch them, but i thought the m2b4 housing was bigger for the lsd and thats why they wouldn't swap over but just measure them, or go for it.
Old Feb 12, 2008 | 09:48 AM
crazi_E's Avatar
Default Re: Will the LSD in my M2B4 swap on to my new M2A4? (dartonh22)
just switch the gears from your m2a4 to you m2b4..but the m2a4 has a shorter gear ratio i believe so its up to you
Old Feb 12, 2008 | 10:07 AM
thomas188's Avatar
Default Re: Will the LSD in my M2B4 swap on to my new M2A4? (crazi_E)
I would assume that you could as the Qualif will fit in any F or H series IIRC... I would think that if you had space for one LSD you would be able to fit another... my .02
Old Feb 12, 2008 | 10:44 AM
CentralCalLude92's Avatar
Default Re: Will the LSD in my M2B4 swap on to my new M2A4? (thomas188)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crazi_E &raquo;</TD></TR><TR><TD CLASS="quote">just switch the gears from your m2a4 to you m2b4..but the m2a4 has a shorter gear ratio i believe so its up to you</TD></TR></TABLE>
Actually the gear ratio is the same. Only difference is the lsd.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WRXnomore &raquo;</TD></TR><TR><TD CLASS="quote">M2B4 missing 2nd and 5th, bought M2A4 as replacement because I could not find another M2B4 in good shape. Seeing as how my LSD is fine, can I swap it to the M2A4? (5th gen. H22a4 manual swap)</TD></TR></TABLE>
You can either open them both up and switch the gears. Or you can put the lsd in the M2A4 but use the M2B4 housing, as the housing is different to support the lsd. As stated by dartonh22.
CTCD5
Transmission & Drivetrain
Nov 1, 2014 09:53 AM
gmcuajo1
Jun 1, 2014 05:55 AM
JDM_EJ8
Nov 15, 2011 08:49 AM
andreasofpartridgetrail
Feb 18, 2007 09:19 AM
