help!!!!!!!!!!! please with swap
Old Feb 11, 2008 | 12:44 PM
streetcartuner's Avatar
Default help!!!!!!!!!!! please with swap
i buying a 97 sol and it has a B18C1
ive drove it and i has great power but it redlines at 6500
its a OBD2a wiring harness and a OBD1 motor it has a OBD2a ecu P72 and im not sure what to do to fix the wiring problem
any help would be great
thank u in advance
please hold all smart comments
and wondering if the wiring harness will all plug in to the motor
Old Feb 11, 2008 | 12:52 PM
b18cDelSlo's Avatar
Default Re: help!!!!!!!!!!! please with swap (streetcartuner)
you mean it has a rev limiter at 6500? or the cluster says 6500?
Old Feb 11, 2008 | 01:03 PM
Default Re: help!!!!!!!!!!! please with swap (b18cDelSlo)
no i wouldnt go any higher
it would stop and hit the rev limiter
what do i need to do to correct this
will the wireing harrness plug into the motor plugs
Old Feb 11, 2008 | 01:08 PM
chuisek9's Avatar
first get and obd2 to obd1 jump harness and get a obd1 p28 or p72!!if u want the harness i got 1 for sale!!
Old Feb 11, 2008 | 02:18 PM
Default Re: help!!!!!!!!!!! please with swap (chuisek9)
how much cuz i can get one from RYwire for 75
will the delly wiring harness plug into the motors plugs
Old Feb 11, 2008 | 03:02 PM
bee20_vtec's Avatar
the jumper harness should b a plug and play
602 bump
Old Feb 11, 2008 | 05:52 PM
852 bump
Old Feb 12, 2008 | 04:28 AM
727 tuesday bump
Old Feb 12, 2008 | 05:09 AM
b18cDelSlo's Avatar
yeah swap the ecu first. then go from there.
Old Feb 12, 2008 | 01:06 PM
but i need to kno if the wire harness will plug in to the motor plugs
Old Feb 12, 2008 | 01:45 PM
4:44 bump
Old Feb 12, 2008 | 04:30 PM
any one
Old Feb 12, 2008 | 07:05 PM
bee20_vtec's Avatar
Default Re: help!!!!!!!!!!! please with swap (bee20_vtec)
yes, its a plug and play
Old Feb 13, 2008 | 05:23 PM
for sur
i need to kno
Old Feb 16, 2008 | 08:00 AM
so i should trade the OBD2A P72 ecu for a OBD1 P72 ecu and just run a jumper harness
Old Feb 16, 2008 | 02:52 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by streetcartuner &raquo;</TD></TR><TR><TD CLASS="quote">so i should trade the OBD2A P72 ecu for a OBD1 P72 ecu and just run a jumper harness </TD></TR></TABLE>
Old Feb 18, 2008 | 01:18 PM
chuisek9's Avatar
hey u still need the harness??
Old Feb 18, 2008 | 02:15 PM
depends on how much u want for it
but ya probaly
woodenchef
17
Jul 14, 2013 10:09 AM
fox_the_shadow
Mar 26, 2012 08:13 PM
tdbhonda
Mar 16, 2009 06:39 PM
TGrant
Apr 19, 2006 02:25 PM
