Stabilizer/Sway bar upgrades
Old Feb 11, 2008 | 12:13 PM
wildcat98's Avatar
Default Stabilizer/Sway bar upgrades
I have a 99 Honda civic with a b18c motor original motor in the car was a d15b what would be the suggested upgardes for the sway bars ?
Honda oem bars preferred ......... other brands can be suggested
Old Feb 11, 2008 | 12:16 PM
B16B_coupe's Avatar
HRD PKR
Default Re: Stabilizer/Sway bar upgrades (wildcat98)
What do you plan to do with the car?
You like understeer or oversteer?
All this plays into factor when wanting upgrades.
But oem ctr, itr rear are def a good choice or asr rear bar 24mm with brace.
26 Si front, 26 gsr front.
Old Feb 11, 2008 | 12:20 PM
4do4damsho's Avatar
Default Re: Stabilizer/Sway bar upgrades (B16B_coupe)
you cant go wrong with the asr brace. then just do 22 mm oem. it'll run just fine.
Old Feb 11, 2008 | 12:30 PM
wildcat98's Avatar
Default Re: Stabilizer/Sway bar upgrades (4do4damsho)
The car has the GSR strut brace i may swap to the Type R Brace.....
Id prefer the car to have neutral steer to slight oversteer
What is the ASR brace ???
whta do you all say ....
26 front
26 rear
Old Feb 11, 2008 | 01:14 PM
B18CivicEJ8's Avatar
http://www.jdmuniverse.com/for...ybars
Old Feb 13, 2008 | 07:08 AM
wildcat98's Avatar
Default Re: Stabilizer/Sway bar upgrades (B18CivicEJ8)
thanks for that info
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18CivicEJ8 &raquo;</TD></TR><TR><TD CLASS="quote">http://www.jdmuniverse.com/for...ybars
meric0786
Suspension & Brakes
Apr 24, 2009 01:24 PM
mr nut
Jan 29, 2007 07:37 PM
shyboi4u
Jun 27, 2006 11:55 AM
deviant1
Acura TSX
Dec 1, 2004 11:46 PM
