Can This be Done: Porsche 944 Turbo Brembo Brake Calipers on Our CaRs
Old Feb 11, 2008 | 07:08 AM
CW-ITR's Avatar
Default Can This be Done: Porsche 944 Turbo Brembo Brake Calipers on Our CaRs
Running across a set similar to this but at a very good price:
http://cgi.ebay.com/ebaymotors...ZWDVW
Thinking about picking up these bad boys for retrofitting. You think it can be done or have anyone done it?
Modified by CW-ITR at 8:31 AM 2/11/2008
Old Feb 11, 2008 | 07:10 AM
walker111's Avatar
Default Re: Can This be Done: Porsche 944 Turbo Brembo Brake Calipers on Our CaRs (CW-ITR)
I think its not worth the trouble.
Old Feb 11, 2008 | 07:11 AM
get RIGHT's Avatar
Default Re: Can This be Done: Porsche 944 Turbo Brembo Brake Calipers on Our CaRs (walker111)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by walker111 &raquo;</TD></TR><TR><TD CLASS="quote">I think its not worth the trouble.</TD></TR></TABLE>
I concur.
Old Feb 11, 2008 | 07:14 AM
migs's Avatar
Default Re: Can This be Done: Porsche 944 Turbo Brembo Brake Calipers on Our CaRs (get RIGHT)
You need to fabricate a bracket very similiar to Stoptech BBK's. It will require alot of work. Also, what diameter is the rotor size? Another area to consider is that the seals in those calipers probably need to be replaced if they havent already.
Fastbrakes.com has alot of affordable and effective solutions for our cars by the way.
http://fastbrakes.com/shop/pro...d=420
$800 for calipers, rotors, pads, and lines.
Old Feb 11, 2008 | 07:42 AM
CW-ITR's Avatar
Default Re: Can This be Done: Porsche 944 Turbo Brembo Brake Calipers on Our CaRs (migs)
Thanks for the link. $800 for a Wilwood brake kit. That's very tempting. I still want to take on the retrofitting route if it is "do-able".
Old Feb 11, 2008 | 08:23 AM
sheekdude's Avatar
Porsche carrera/boxter calipers can be used, but the rears though. They are 4 pot pistons. I'm awaiting a set of custom brackets from another h-t user to mount them on my itr right now. I'll let you know how it works out.
I don't want to put unrealiable information out there. But the h-t user told me he has them on his car right now... so i'm awaiting the actual brackets and mounted pictures.
Old Feb 11, 2008 | 08:24 AM
walker111's Avatar
Old Feb 11, 2008 | 08:25 AM
walker111's Avatar
Anything is do-able. but "worth it" is the question. Plus they say porsche on the them
Old Feb 11, 2008 | 08:43 AM
CW-ITR's Avatar
Default Re: Can This be Done: Porsche 944 Turbo Brembo Brake Calipers on Our CaRs (sheekdude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sheekdude &raquo;</TD></TR><TR><TD CLASS="quote">Porsche carrera/boxter calipers can be used, but the rears though. They are 4 pot pistons. I'm awaiting a set of custom brackets from another h-t user to mount them on my itr right now. I'll let you know how it works out.
I don't want to put unrealiable information out there. But the h-t user told me he has them on his car right now... so i'm awaiting the actual brackets and mounted pictures.</TD></TR></TABLE>Alright, please keep me/us update on your set up. From what I heard, the clamping force on the Porsche/Brembo is greater than Willwood.
Old Feb 11, 2008 | 08:44 AM
CW-ITR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by walker111 &raquo;</TD></TR><TR><TD CLASS="quote">.... Plus they say porsche on the them </TD></TR></TABLE>That can be fix. I'll just grind the "Porsche" lattering and put on the "Brembo" sticker and call it the day
Old Feb 11, 2008 | 09:37 AM
jomama's Avatar
wilwoods: too costly/troublesome to rebuild when need be. get a set of legend or nsx calipers and call it a day. no need to dick around with fabbing up brackets and what nonsense.
Old Feb 11, 2008 | 11:39 AM
ComeOnKip's Avatar
From: Where the wild things are in, NY, United States of America
Default Re: (jomama)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jomama &raquo;</TD></TR><TR><TD CLASS="quote">wilwoods: too costly/troublesome to rebuild when need be. get a set of legend or nsx calipers and call it a day. no need to dick around with fabbing up brackets and what nonsense.</TD></TR></TABLE>
uhhhh no. I stock all of the parts to rebuild a wilwood caliper, including pad wear plats, bridge bolts and pad retaining pins. It costs like ~$30 to rebuild one with new everything sans pistons.
Old Feb 11, 2008 | 12:02 PM
tartje's Avatar
Default Re: (ComeOnKip)
you can outbrake your tyres anyway on stockers, it's not something I've ever felt needs to be fiddled with, unless it's a dedicated track car
Old Feb 19, 2008 | 02:24 PM
GPNY's Avatar
Default Re: (tartje)
I'm in for Boxter caliper bracket pictures. What size disc would they use?
I'm looking for a 4pot setup that would work on 11.1" discs and still clear Milleninia wheels... but I don't want to spend 1K+ on Spoons...
Old Feb 19, 2008 | 03:58 PM
mtny's Avatar
Default Re: (GPNY)
Checkout Justin's brakes.
http://www.hondamarketplace.co...01585
Old Feb 20, 2008 | 07:12 AM
jomama's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ComeOnKip &raquo;</TD></TR><TR><TD CLASS="quote">
uhhhh no. I stock all of the parts to rebuild a wilwood caliper, including pad wear plats, bridge bolts and pad retaining pins. It costs like ~$30 to rebuild one with new everything sans pistons. </TD></TR></TABLE>
i stand corrected.
Old Feb 20, 2008 | 07:14 AM
jomama's Avatar
Default Re: (mtny)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mtny &raquo;</TD></TR><TR><TD CLASS="quote">Checkout Justin's brakes.
pretty badass... i PMed him on how much he sold them for
Old Feb 20, 2008 | 07:38 PM
iheartintegras's Avatar
there's a guy here on HT that sells brake upgrade kits. He quoted me I think $450 for complete front s2k brake conversion for my itr
Old Feb 21, 2008 | 04:47 AM
dickdragon's Avatar
there's a write up on using porsche calipers on a dc2 4-lug on http://www.importatlanta.com.
search it! hope it helps
Old Feb 21, 2008 | 07:20 AM
jomama's Avatar
Default Re: (iheartintegras)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iheartintegras &raquo;</TD></TR><TR><TD CLASS="quote">there's a guy here on HT that sells brake upgrade kits. He quoted me I think $450 for complete front s2k brake conversion for my itr</TD></TR></TABLE>
yep, BrakeExpert. he's a good guy and knows what he's doing... though some of it maaaay be a little unorthodox.
Old Feb 21, 2008 | 08:10 AM
CW-ITR's Avatar
Default Re: (dickdragon)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dickdragon &raquo;</TD></TR><TR><TD CLASS="quote">there's a write up on using porsche calipers on a dc2 4-lug on http://www.importatlanta.com.
search it! hope it helps</TD></TR></TABLE>It seems you have to be a member before you can access to the site.
Old Feb 21, 2008 | 09:12 AM
mtny's Avatar
Default Re: (CW-ITR)
Justin's brakes were "made" by the guy who did the write up on Import Atlanta (I think).
Old Feb 21, 2008 | 10:07 AM
EH-3's Avatar
Default Re: (mtny)
link to write up?
Old May 2, 2008 | 11:24 PM
jonbwnnab22554's Avatar
Hey I was interested in your aspec suspension. Wondering if you could email me at JONBWNNAB1@CS.COM I cant us PM yet or post in marketplace.
Old May 4, 2008 | 07:15 AM
teg97's Avatar
Default Re: (mtny)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mtny &raquo;</TD></TR><TR><TD CLASS="quote">Justin's brakes were "made" by the guy who did the write up on Import Atlanta (I think).</TD></TR></TABLE>
justin bought the guys brakes that he made for his integra. I know the guy who made these but not sure if he can make them anymore. He used to work in a race shop and had access to many machines to make them fit.
