Timing Belt Cover - do I need to replace it?
Old Feb 11, 2008 | 04:29 AM
rmiller's Avatar
Default Timing Belt Cover - do I need to replace it?
Hi, I'm doing a swap of a 97 Accord F22B1 for a H23A1 into my 95 Prelude. I was going to replace the timing belt on the F22 since that's what broke on the H23 and I think it's been done already.
The reason I say this is the lower cover has a hole in it from the belt rubbing. It looks like the cover was never (re)installed correctly and the top edge around the crankshaft pulley wasn't seated behind the pully but was in front, hence the rub of the belt.
My buddy says not to replace the cover and that this problem even exists on engines as they leave the factory.
I wanted to get some more opinions before I decide.
Thoughts?
Thanx
RJ
Old Feb 13, 2008 | 05:14 AM
rmiller's Avatar
Default Re: Timing Belt Cover - do I need to replace it? (rmiller)
Any body?
Old Feb 13, 2008 | 01:19 PM
pinecone's Avatar
i would put them back on, just to keep stuff from flying in there.
Old Feb 13, 2008 | 06:51 PM
LudeBB6's Avatar
Default Re: Timing Belt Cover - do I need to replace it? (pinecone)
i agree, you might as well just do it.
bdmlilburn
Jul 24, 2011 07:54 AM
Wild_Dima
Mar 21, 2007 06:16 AM
noble4ws
Nov 11, 2003 05:27 AM
