telling what kind of crx i have
Old Feb 11, 2008 | 02:27 AM
xNRxJose's Avatar
Default telling what kind of crx i have
i own a 1990 honda crx
im not sure if its base,si,or hf
how can i tell?
im positive its base.
and also where can i get an axle or cv joint because when i ride it, it goes up and down.
when it went up on a lift and spun the tire would waddle
Old Feb 11, 2008 | 03:13 AM
rd91sib18c5r's Avatar
Default Re: telling what kind of crx i have (xNRxJose)
Does it have a sunroof or a tach. Sounds like you have a wheel bearing out,
not a cv. When a cv goes out it will click when turning.
Old Feb 11, 2008 | 03:22 AM
~sp33~'s Avatar
EFB055
Default Re: telling what kind of crx i have (rd91sib18c5r)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rd91sib18c5r &raquo;</TD></TR><TR><TD CLASS="quote">D
not a cv. When a cv goes out it will click when turning. </TD></TR></TABLE>
Spot on, post some pics of your car, we will be able to tell you what model you have pretty quickly.
Old Feb 11, 2008 | 03:37 AM
Crx Jimmy's Avatar
go to the dealer with the vin, its the only way to really tell. Anyone could have put a new roof skin on or swapped motors.
Old Feb 11, 2008 | 04:32 AM
~sp33~'s Avatar
EFB055
Or shaved off and re engraved the vin.
Old Feb 11, 2008 | 06:42 AM
ludesrv's Avatar
The likehood of either of those previously mentioned options are low.
It's it's DPFI then it's for sure a base model. If it's MPFI it's SI or HF, and if it's SI you will have a electric sunroof.
Old Feb 11, 2008 | 08:13 AM
97SS's Avatar
Here's a few more things to tell if you've got a DX, Si, or HF...some have already been repeated by oh well...
- HF Engine block reads D15B6, DX engine blcok reads D15B2, Si will read D16XX (I don't know since I've never looked for an Si)
- Si will say 16 Valve or VTEC on your valve cover
- HF Stock steering wheel have 2.
- HF don't have a rear hatch wiper, DX and Si's do.
- HF tach redline start at 5000rpm.
- Under hood will say MPFI for HF and SI. DX will say DPFI.
- Only DX came with automatic transmission.
- Si seats have side bolstering that go all the way to the top and have a hole in the head rests.
- DX seats have side bolstering that go all the way to the top like Si but don't have a hole in the head rests.
- HF seats have side bolstering only up to about half the way back portion and don't have a hole in the head rests.
Also try doing a google search for your VIN and click on the only link (a carfax link) and it will give you the basic info about your car and about 90% of the time it also tells you the model trim (Si, DX, or HF).
Good luck.
Old Feb 11, 2008 | 08:18 AM
IT GUY's Avatar
Default Re: telling what kind of crx i have (97SS)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97SS &raquo;</TD></TR><TR><TD CLASS="quote">
won't say VTEC on a USDM car form 88-91 unless the motor is swapped.
also, my 91 std hatchback (d15) said 16 valve even though it was DPFI
Old Feb 11, 2008 | 09:10 AM
Bob_760's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97SS &raquo;</TD></TR><TR><TD CLASS="quote">- HF Engine block reads D15B6, DX engine blcok reads D15B2, Si will read D16XX (I don't know since I've never looked for an Si)</TD></TR></TABLE>
Si is D16A6
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97SS &raquo;</TD></TR><TR><TD CLASS="quote">- Si will say 16 Valve or VTEC on your valve cover</TD></TR></TABLE>
Si/DX will say 16 Valve, HF will say 8 Valve, none will say VTEC.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97SS &raquo;</TD></TR><TR><TD CLASS="quote">- HF Stock steering wheel have 2.</TD></TR></TABLE>
2 spokes instead of 3.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97SS &raquo;</TD></TR><TR><TD CLASS="quote">- HF don't have a rear hatch wiper, DX and Si's do.</TD></TR></TABLE>
Rear wiper was optional on DXs neither of mine have one. Allthough I think all Sis have a rear wiper and no HFs do.
Old Feb 11, 2008 | 09:11 AM
scottmog's Avatar
wow 97ss good job
my personal opinion, sun roof or not?
then what color is the interior? u can most likely get your answer with those two questions
Old Feb 11, 2008 | 11:08 AM
97SS's Avatar
Default Re: telling what kind of crx i have (Mog)
Thanks for the corrections/clarification fellas....I knew I would have some typos.
Old Feb 11, 2008 | 12:26 PM
xNRxJose's Avatar
yeah when i would break it would click
so even if its my cv joint could i get just an axle assembly to fix it all.
heres my carfax info: so what type do i have
Modified by xNRxJose at 9:35 PM 2/11/2008
Old Feb 11, 2008 | 12:29 PM
CRX Toad's Avatar
You have a Honda CRX.
You do not have a Honda CRX Si
You do not have a Honda CRX Hf
There was no Honda CRX DX, it is just a Honda CRX with a D15B2 Dual Point.
Old Feb 11, 2008 | 01:08 PM
97SS's Avatar
Default Re: telling what kind of crx i have (CRX Toad)
Toad's right...there weren't any CRX DX's...so you have a base CRX.
I belive they did have a Civic DX model at the time so I think that's where the DX creeps in CRX lingo.
Plus I'm sure someone can correct me on this but I'm 99% sure CRX's were originally sold as a Civic CRX, so there's another way for the Civic DX trim creeping into the CRX world
You definately have a base (not a HF or Si)
Old Feb 11, 2008 | 08:36 PM
xNRxJose's Avatar
sweet thanks alot
Old Feb 11, 2008 | 08:50 PM
scottmog's Avatar
97SS that is strange, when i had a "dx" haha they always had that question at a car shop.
from them...
what year? 1990
what make? honda
what model? crx
what type model? dx
dx was always in there databases, maybe they just cant put "base" lol, no idea @@
rexie
Feb 16, 2008 04:48 PM
clemsonteg
Jan 4, 2008 09:22 PM
nk2k2
Jul 5, 2006 02:28 PM
SexyAzNMami
Jun 11, 2005 06:15 PM
IEATLINT
Jul 2, 2003 06:58 PM
