DX to SI wiring help
I have a 90 EF hatch that had a d15b7 in it with some expletiveed up wiring. I just got a SOHC zc with a SI harness on it i need to get it running wiring wise
i see that all of the threads say to convert the dx harness using the si harness but i dont have the dx harness i need to make the si harness work can anyone help me
i have a 90 EF hatch and i know and have read all the forums and stuff saying that you cannot use the si harness on a dx car but here is my problem i got the car with no engine harness but have a full car crx si harness what is the best thing i can do could i cut and match the under the dash to the crx si ecu plugs and engine harness or would it be easier to replace the whole under dash harness i dont have anymore money at the moment to put into this car but i do have time
ok the si harness will work just connect it to the motor as is and then plug in the 2 plugs that are the same now for the other plug u have to run wires to the ecu for that. I dont have the wiring diagram but can look around.
