Kteller Exhuast help
Old Feb 10, 2008 | 08:18 PM
elitesi8's Avatar
Default Kteller Exhuast help
So I got a great deal on a SS Kteller exhuast, problem is that I can't get the 2 peices separated so I can install them. It has the 2 pieces that slide together and have a clamp over them, after loosening the clamp I can't get them apart. I've already tried WD40. I don't want to have to cut them apart and weld back.
Modified by elitesi8 at 9:35 PM 2/10/2008
Old Feb 10, 2008 | 08:23 PM
93egSLEEPER's Avatar
Default Re: Kteller Exhuast help (elitesi8)
can we get a pic of the problem maybe?? hard to understand exactly whats going on from your discription
Old Feb 10, 2008 | 08:26 PM
Mugen112's Avatar
try using a propane torch on the outer pipe to expand it. be careful, things get hot real quick.
Old Feb 10, 2008 | 08:36 PM
elitesi8's Avatar
Default Re: (Mugen112)
^edited
Old Feb 10, 2008 | 08:44 PM
Default Re: (elitesi8)
is it like press fit together?? it may have to be cut if thats the case... heat wont touch that.
Old Feb 10, 2008 | 08:46 PM
elitesi8's Avatar
Default Re: (93egSLEEPER)
Yeah, when first installed the 2 parts slid into each other, but after the clamp was put on and tightned down its just stuck together.
Old Feb 10, 2008 | 09:00 PM
have you tried to just bend them opposite directions quickly and pull?
Old Feb 10, 2008 | 09:10 PM
elitesi8's Avatar
Oh yeah, as you can see in the pic I've tried a hammer too, I am thinking about using a cargo strap and pulling it apart with my truck. I just talked to the guy I bought it from and he said he disconnected his lower control arm and put it on that way, didn't want to have to do that but...
Old Feb 10, 2008 | 11:48 PM
saywhat's Avatar
Not sounding like such a great deal now... Damn, maybe take to a muffler shop and see if they can separate it, I'm sure they run into this stuff all the time.
EDIT: maybe some large pipe wrenches?
Old Feb 11, 2008 | 08:31 PM
elitesi8's Avatar
Default Re: (saywhat)
I got it apart today, just needed some serious muscle and a crap load of WD 40. Will post up pics when installed. Thanks guys!
Integraoligist
Oct 4, 2012 07:59 PM
bdubnyc
23
Oct 14, 2008 06:06 PM
sharbel
May 18, 2008 09:35 AM
crazyguy
Mar 4, 2008 04:58 PM
90LSpimpin
32
Mar 20, 2005 10:49 PM
