mpfi swap complete no start
Old Feb 10, 2008 | 04:13 PM
thedudefromjerz's Avatar
Default mpfi swap complete no start
just finished a mpfi swap on my 90 dx. I used a z6 im. the motors cranking but wont start. Its throwing a code 1. o2 sensor i believe. But that wuldnt keep it from starting right? any help is apreciated.
Old Feb 10, 2008 | 05:43 PM
jedb18's Avatar
Default Re: mpfi swap complete no start (thedudefromjerz)
check thermostat ground
Old Feb 10, 2008 | 06:01 PM
DenzComp's Avatar
Try swapping the two white wires at the Dizzy.
Old Feb 10, 2008 | 08:21 PM
Default Re: (DenzComp)
I already changed the wires, and before i did i was getting a code 15, or 16 i forget. and since i changed them now im just gettin code 1.
Old Feb 14, 2008 | 02:15 PM
Default Re: (thedudefromjerz)
(update) still wont start even after trying to switch the white wires numerous times. Still throwing code only a code 1. I need advice. what should I check. thanks.
and if thermostat ground runs into the wiring harness then it seems fine to me.
Old Feb 14, 2008 | 03:26 PM
x4thGenCafe's Avatar
OF THE KINGS
have you switched the White wries at the dizzy ??
Old Feb 14, 2008 | 07:58 PM
Default Re: (x4thGenCafe)
yes I tried switching the two white wires at the dizzy.
88_hatchattack
Oct 25, 2018 01:05 PM
Justin95-si
Apr 25, 2012 10:56 PM
Slotz_HB
Sep 18, 2009 01:56 PM
apekd
Feb 21, 2009 05:09 PM
JDMlyfestyle
Oct 13, 2005 05:45 PM
