EG struts on a EM1?
I'm curious. I bought some Ground Controls for my Si. The dude threw in the struts he had on them for free because he got all new suspension. Only 1 is blown but anyways, I told my friend I was going to put the whole set-up on my Si. He said they won't fit due to something on the control arm or something of that sort. I thought all 92-00 struts were the same? I tried searching but nothing. help me out fellas. thanks.
Fronts will fit no problem. You'll need spacers between the LCA bushing and strut fork in the rear. But yeah, they fit.
If you plan to put EK struts on an EG, you'll need to shave down the LCA bushings.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueIntegraBoy »</TD></TR><TR><TD CLASS="quote">Fronts will fit no problem. You'll need spacers between the LCA bushing and strut fork in the rear. But yeah, they fit.
If you plan to put EK struts on an EG, you'll need to shave down the LCA bushings.</TD></TR></TABLE>
to be able to use DC/EG struts on your EM1, you'll need spacers which is also known as washers. Washers can be bought from any autopart store or any home depot, Orchard, and etc....
just wanted to clear things up BlueIntegraBoy...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bmoua »</TD></TR><TR><TD CLASS="quote">
I was in a rush.
I was in a rush.
truevietluv636
Oct 18, 2006 07:36 PM
92JDMSiR
Apr 6, 2003 12:47 AM
