crx engine wire harness?
Old Feb 10, 2008 | 05:31 AM
tree fingers's Avatar
Default crx engine wire harness?
I need an uncut 88-91 wiring harness to convert to si for a b-series swap. I found an 88-91 harness, but it is for a CRX. I assume, since the cars share the same engine?, that these harnesses would be the same. Would this work?
This might be a really dumbass question.
but, please excuse my ignorance.
please&thanks
Old Feb 10, 2008 | 09:26 AM
black0hatch's Avatar
Default Re: crx engine wire harness? (tree fingers)
all 89-91 si engine harnesses are the same doesnt matter if its crx or hatch. 88 si harness is different cause it has a square plug on drivers side instead of circle. im guessing you have a dx and need to convert it to mpfi if thats the case you dont need an uncut si harness cause your gona need to cut it anwase for the plugs. you need 4 injector plugs, round dizzy plug, and reisitor box plug. you can also get all those plugs off a obd0 teg harness. no matter what you use your stock harness for your car. you cant plug a si hanress into a dx.
Old Feb 10, 2008 | 10:21 AM
Default Re: crx engine wire harness? (black0hatch)
Oh, sorry.. I meant 89-91. oops. Thanks, I really appreciate it. The wiring might be a bit over my head, and I'm not sure if I wana mess with it. I might get the dx harness, and whenever the integra harness comes back in I'll just send them to rywire. I'm electrically retarded.
Thanks man
Old May 30, 2008 | 03:19 AM
hondafleet82's Avatar
Im doing a B20 Vtec swap in my 91 DX CRX. I picked up a PW0 and was thinking about doing some cut and sew on a harness. I opted out because I thought it was a little over my head and I didnt know if I would have the time and patients to get it done. I just went online Rywire.com to buy one from them. I have heard good things about them and its pretty cheap. Not to mention the peace of mind knowing you didnt screw anything up.
Old May 30, 2008 | 04:53 AM
gibsanez's Avatar
Default Re: crx engine wire harness? (hondafleet82)
If you're not confident, get in contact with rywire. I've seen some really nice and straightforward jumpers and whatnot on the site and in person. Trusted stuff
Old Jun 22, 2012 | 08:15 PM
sentualguy's Avatar
Thanks man
i think i went to rywire and i dont think they mess with ur wire harness no more cause they been getting pretty bad harness's back. They should have a completely new wire but im not too sure if they have my wire harness cause all i saw was the d16 and mine is a d15
Old Jun 22, 2012 | 08:24 PM
crx_si-r's Avatar
you just responded to 5yr old post. and rywire no longer does dpfi to mpfi harnesses.
txt me 916-541-5266
Old Jun 22, 2012 | 08:34 PM
sentualguy's Avatar
txt me 916-541-5266
im a new user and im trying to post at least five postings or wait fifteen days so i wont just be a trial user
thecruzs2007@yahoo.com
Nov 22, 2011 11:57 AM
janz3n
Nov 11, 2008 09:43 AM
HBK
Jan 12, 2006 01:59 PM
Sammex
Dec 20, 2003 02:28 AM
crxracerr69
Jul 13, 2002 02:59 PM
