Deference between B16A6 crank and ..
Old Feb 10, 2008 | 04:47 AM
DelSolMaker's Avatar
Default Deference between B16A6 crank and ..
Hi after a long search in the site I have to ask this question where I did not find the answer to it.
Problem: Crank shaft pulley key way worn out and thread gone.
I got my crank out of the block and tried to get it repaired but no use it's not reparable.
I have to find a new crank, pulley and the bolt but I am not able to find a B16A6 crank.
So what other crank I can use.
I was told I can't use another B16Ax crank and if I will use I have to do some modification and I don’t want to do any modifications.
I have found a B16A2 engine and I am not sure if it will fit in my 1996 manual Delsol or any other B16Ax engine will fit in my car.
If so please advice on the engine number and I will find it out and fix my car.
Thanks
Old Feb 10, 2008 | 07:09 AM
Deetz's Avatar
Crazy Honda Guy
Default Re: Deference between B16A6 crank and .. (DelSolMaker)
There is no reason why you shouldn't be able to use another b16 crank in that engine. Even if it mean buying new bearings, it shouldn't be a problem. You shouldn't have much problem finding one, i've have extra's myself, and always just end up giving them away....don't have any extra at the moment though
Old Feb 12, 2008 | 03:46 AM
Default Re: Deference between B16A6 crank and .. (Deetz)
Thanks mate it's very nice to hear that from you I think I will use the old crank what I will do is:
I will wild the key way and get it done again and I got a new 2nd hand pulley from a B16A it's not the same but I think it will do the work I believe that this is only to run the Alternator, P/S and the A/C I don’t think running some belts will crate a problem if the pulley is not having rubber seal in the back side?
I will try to update you with some pictures ASAP.
4.8t
20
Feb 12, 2012 03:07 PM
212 degrees
Jun 8, 2009 08:09 PM
mar778c
Feb 4, 2007 07:14 PM
Jammersplace
Oct 17, 2004 10:01 PM
DarkSol97
Aug 14, 2002 06:29 AM
