JDM Climate Control...
Old Jul 3, 2002 | 02:35 PM
AllMotorITR's Avatar
New User
Default JDM Climate Control...
Anybody have pics of the JDM Climate Control Unit? How does it differ compared to the USDM unit?
Old Jul 3, 2002 | 02:46 PM
Reid's Avatar
Global Moderator
Default Re: JDM Climate Control... (1 FAST R)
It doesn't.
Old Jul 3, 2002 | 02:56 PM
New User
Default Re: JDM Climate Control... (Reid)
A friend of mine has one for sale, I have not looked at it yet, but he told me that instead of having the blue-to-red temperature gauge, it has specific temperatures.
Old Jul 3, 2002 | 02:58 PM
Reid's Avatar
Global Moderator
Nope.
I have one.
No difference.
Old Jul 3, 2002 | 03:09 PM
New User
I wonder what climate control he is talking about... Hmm...
Old Jul 3, 2002 | 03:12 PM
Reid's Avatar
Global Moderator
I know the 89-92 JDM Integras had numbers while the 90-93 USDM Integras had colors. Also the JDM Integras had digital climate control. Oooh... digital.
Old Jul 3, 2002 | 03:13 PM
New User
So your JDM climate control is digital? I thought you said that it did not differ...
Old Jul 3, 2002 | 03:16 PM
Reid's Avatar
Global Moderator
That's on the G2 Integras.
The JDM ITR climate control is from a Type Rx and it's identical to the USDM one. The only difference is the hazard and rear defrost buttons are switched.
Old Jul 3, 2002 | 03:17 PM
New User
Then why did you buy one?!
Old Jul 3, 2002 | 03:20 PM
mugenracer's Avatar
JDM cars do have numbers on the slider control...20 being coldest, 25 - mid and 30 hottest.
Reid's Avatar
Global Moderator
I didn't.
I received a '98 Spec spark plug wire cover and climate control for free.
Old Jul 3, 2002 | 03:21 PM
New User
Default Re: JDM Climate Control... (mugenracer)
are you sure?
Old Jul 3, 2002 | 03:26 PM
Reid's Avatar
Global Moderator
D'oh!
I'll double check when I get home.
That'll end this once and for all.
Old Jul 3, 2002 | 03:28 PM
New User
Reid, how do you know yours is JDM? Anyone can switch the places of the defrost and hazard buttons... Somebody got jacked.
Old Jul 3, 2002 | 03:31 PM
C Squared's Avatar
pic stolen from integra.vtec.net
interior of JDM Integra Type R climate control is the same as USDM except for the trim and the hazard and defrost buttons switched, also lights up amber. In Regular JDM R's the trim is faux CF just like the R's here
HTH
[Modified by Mooshu, 4:34 PM 7/3/2002]
Old Jul 3, 2002 | 03:36 PM
Reid's Avatar
Global Moderator
It's JDM.
Old Jul 3, 2002 | 03:39 PM
freakie's Avatar
The JDM ones, are as the person above described. Climated control has the 3 numbers 18 - 25 - 30 they are in white, and so is the - between the numbers. The 18 has a blue sqaure under it adn the 30 has a red square under it. on the fan control (right side) you cna select a function called auto, then u get the usualy smallest to largest exponential colums from smallest to largest.
For the selection of where you want the air to go, the first one on the left has auto function, then u haev teh normal vent, then feet, then feet/demister, then demister.
I hope that description helps. Btw they are not digital display prior to 96, but after that i am unsure. i might be able to take a shot with adigi cam later to show you what i mean, but ucna probably figure it out form what i said.
Old Jul 3, 2002 | 03:41 PM
Reid's Avatar
Global Moderator
Default Re: JDM Climate Control... (freakie)
No, you're incorrect.
To clarify, we're talking about a DC2 JDM ITR climate control. Let's not confuse the issue here.
Also see above pic.
Old Jul 3, 2002 | 05:57 PM
mugenracer's Avatar
There is NO climate control on ITR in the picture above, just a/c. If it had climate control, there would be an AUTO button on the far left and also an AUTO setting on the fan control before 1 and after OFF. ITRs with A/C only used the blue/red slider indicator, whereas one with climate control have 20-25-30 on the slider control.
[Modified by mugenracer, 7:06 PM 7/3/2002]
Old Jul 3, 2002 | 09:06 PM
freakie's Avatar
as mugen racer said, thats what i see in my car... But the unit was from a vtir (the normal vtec ones) from japan. My R is a JDM imported one, but it didnt come with the climate control....
it does have air cond stock though.
Old Jul 3, 2002 | 09:35 PM
Mike M's Avatar
Founding Member
I believe the solution is for someone to Go IM Dee
PS I'm pretty sure Reid is correct, "Climate Control" wasnt available on the DC2R as far as I know, Maybe on a regular model, but then again the color would be white not amber.
Old Jul 3, 2002 | 09:38 PM
New User
Default Re: JDM Climate Control... (TypeRmsm)
Wait a second, I am getting a little confused on what everyone is considering "climate control" to be. In my original post, I am referring to the temperature (red/blue line)
Old Jul 3, 2002 | 09:39 PM
Reid's Avatar
Global Moderator
Chris,
Read what I said above. Mike vouched for me if that helps.
Ignore the posts that go against what we've said.
Old Jul 3, 2002 | 10:45 PM
Mr. Thunderlips's Avatar
Please, one last time for all the difficult people here. It is exactly the same, except it lights up amber. Fin.
Old Jul 3, 2002 | 10:47 PM
Mike M's Avatar
Founding Member
Default Re: JDM Climate Control... (ThunderLips)
ALL ITR's have amber lighting
