Suspension & Brakes Theory, alignment, spring rates....
Ground Control Top Hat question
Old Feb 10, 2008 | 12:51 AM
AlwayzSpoolin's Avatar
Default Ground Control Top Hat question
Has anyone used Ground Control Top Hats on any other coilover ? Trying to find out if they will work with my Skunk2 Coilovers. I was on their webstie and said will only work with ground control kits. But just seeing if they will work. Thanks
Old Feb 10, 2008 | 12:26 PM
Tyson's Avatar
Default Re: Ground Control Top Hat question (AlwayzSpoolin)
itll work. the spring just needs to fit the 2.5" ID.
Old Feb 10, 2008 | 12:59 PM
Default Re: Ground Control Top Hat question (Tyson)
Sweet ! Im gonna order a set tomorrow. What do you mean " Fit the 2.5" ID " ?
Old Feb 10, 2008 | 03:11 PM
Rob.'s Avatar
wont work.
The shock body has to fit inside the hole of the top hat.
I beleive Koni shocks are the only ones that fit, not sure about KYB and such.
Old Feb 10, 2008 | 08:24 PM
Tyson's Avatar
Default Re: Ground Control Top Hat question (Rob.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rob. &raquo;</TD></TR><TR><TD CLASS="quote">wont work.
I beleive Koni shocks are the only ones that fit, not sure about KYB and such.</TD></TR></TABLE>
lol... so funny. who told you this?
anyway, what rob is talking about is if youre using a "full coilover". in that case it wont work. or is needed.
if youre just trying to fit it on skunk2 "sleeve over" than its fine. 2.5" ID refers to the inside diameter of the spring. most sleeve overs are 2.5" ID anyway, because they all copy GC.
Old Feb 11, 2008 | 01:13 PM
omnirage's Avatar
It depends on the diameter of the tube that comes out of the shock body...the GC mount also tapers on the inside. It probably won't work right out of the box.
Old Feb 11, 2008 | 02:01 PM
Default Re: Ground Control Top Hat question (omnirage)
Im not using a full bodied coilover... Im using Skunk2 Sleeve coilovers like the GC's . Thanks for clearing that up Tyson ! Ordered a set this afternoon ! Thanks guys ..
JHall250
52
Jun 14, 2018 07:23 AM
danis one
Suspension & Brakes
Jun 30, 2010 11:55 PM
wideeg
Suspension & Brakes
Apr 1, 2009 07:02 PM
b16a4
Suspension & Brakes
Mar 4, 2007 04:33 PM
89civicdx
Jul 8, 2001 02:21 PM
