help!!!! passenger side axle slight wobble on inner joint??? help!!!!!!!!!!!
Old Feb 9, 2008 | 11:40 PM
rhdekhatchie's Avatar
Default help!!!! passenger side axle slight wobble on inner joint??? help!!!!!!!!!!!
im having alot of vibration from my front end i noticed my front passenger axle has a slight wobble to it at the end that plugs into the tranny. i checks axle nut and its tight so theres no loosness in the wheel once jacked up there in no play at all. i ca see axle from top of engine bay and jacked car up and started car, i put it in first and noticed that the axle is wobbling a bit is this just needing a new axle??????
any help would be appreciated
Old Feb 9, 2008 | 11:50 PM
meandino's Avatar
Default Re: help!!!! passenger side axle slight wobble on inner joint??? help!!!!!!!!!!! (rhdekhatchie)
I would replace it
Old Feb 10, 2008 | 12:02 AM
JarvisW's Avatar
Sol to Sol
Default Re: help!!!! passenger side axle slight wobble on inner joint??? help!!!!!!!!!!! (meandino)
Did you hit a curb? lol
But yeah, Axles with lifetime warrantys are around $80 each, so might as well replace it.
Oh, and I'm not sure what side its wobbling, but it MIGHT also be bearings?
Old Feb 10, 2008 | 04:07 PM
yeah i think im just gonna replace it i mean the axle looks fine but it may be something internally in the boot thats got the axle jacked up
Old Feb 10, 2008 | 04:08 PM
Default Re: help!!!! passenger side axle slight wobble on inner joint??? help!!!!!!!!!!! (JarvisW)
hell naw i didnt hit no curb....lol
i think its just a bad axle imma replace it gand go from there and also check bearings, thanks for the help
Old Mar 16, 2008 | 10:17 PM
h22apwrdcivic's Avatar
well did this fix your problem or what?
taimysho0
Jul 8, 2009 01:29 PM
WRTEG
Jul 20, 2006 01:43 PM
JSpin
Mar 26, 2004 08:52 PM
ill phil
May 15, 2003 06:27 PM
Smashback
Apr 10, 2003 11:09 AM
