2 wire 02 sensor.... Cant find a replacement
Old Feb 9, 2008 | 09:11 PM
Lude-Lee's Avatar
Default 2 wire 02 sensor.... Cant find a replacement
Okay went to go look for a 02 sensor for my car, Went to autozone,napa,advance, etc come to find out that I have a 2 wire connector, and all they have is a 4 wire replacement 02 sensor.
what i want to know is where can i get a 2 wire 02 sensor?
And my Bank one connector is round and green not like the secondary connector which is grey.
For a 4th gen h22a
Old Feb 10, 2008 | 12:06 AM
Acidcrakker's Avatar
Default Re: 2 wire 02 sensor.... Cant find a replacement (Lude-Lee)
Are you sure that its the O2 sensor your looking at and not something else.
OBD1 the O2 sensor is in the Downpipe
Old Feb 10, 2008 | 12:47 AM
JT's Avatar
JT
You might be looking at the wrong connector, as there's no secondary O2 sensor for an OBD1 (4th gen). Your O2 sensor should have a 4-wire connection.
Old Feb 10, 2008 | 05:08 AM
vlang29's Avatar
Yeah, you must be looking at another sensor. O2 is right before the cat, and has 4 wires on all 92-95 ludes.
Old Feb 10, 2008 | 06:01 AM
Lude-Lee's Avatar
Default Re: 2 wire 02 sensor.... Cant find a replacement (vlang29)
Its weird, its like my megan racing header comes with one whole for the o2 so i when to two people and they say we can Buge and drill in the header to put another 02.
Im running on 96 obd2.
Old Feb 10, 2008 | 06:17 AM
Lude-Lee's Avatar
Maybe i'm looking at the wrong sensor. But does anybody know where its at.
I have one pluged up before cat (Short one)...What i want to know is, is there another grey connector beside the green round one on the harrness?
Old Feb 10, 2008 | 06:25 AM
v4lu3s's Avatar
RTFM
there is one o2 sensor before that cat in the downpipe below the intake manifold, it has a gray 4 wire plug. there is a second one IN the catalyst under the car, it is connected under the car with a 4 wire gray plug as well.
Old Feb 10, 2008 | 07:01 AM
m00nr0ck Si's Avatar
Default Re: (v4lu3s)
get an ngk replacement right here http://sparkplugs.com/
Old Feb 10, 2008 | 07:13 AM
vlang29's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lude-Lee &raquo;</TD></TR><TR><TD CLASS="quote">I have one pluged up before cat (Short one)...What i want to know is, is there another grey connector beside the green round one on the harrness?</TD></TR></TABLE>
You mean there is just a plug in the header and not an oxygen sensor?
That is where the primary O2 sensor needs to be installed.. The connector is a square gray plug that is just above the oil filter
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lude-Lee &raquo;</TD></TR><TR><TD CLASS="quote">Its weird, its like my megan racing header comes with one whole for the o2 so i when to two people and they say we can Buge and drill in the header to put another 02. </TD></TR></TABLE>
If you have stock exhaust, you shouldn't need to weld in a bung for the secondary.. it's immediately after the cat on stock exhaust
Old Feb 10, 2008 | 11:36 AM
Lude-Lee's Avatar
Thanks ya'll. Find the plug and now i feel like an idiot
Replaced the 02 sensor with one I took off another lude.
Car runs 10x better
-No hesitation
-No CEL
-More throttle response
-Pretty beast now...
THX
minituner
Mar 26, 2016 04:16 PM
BLUE EH3
May 16, 2005 07:24 PM
LsTurbo91
Oct 8, 2001 09:20 PM
