Shifting problem after long periods of time
Old Feb 9, 2008 | 07:37 PM
ramos2589's Avatar
Default Shifting problem after long periods of time
After driving my 93 honda civic for a while, i can't change gears, i literally have to pull the gear in with alot of force... i noticed my shift linkage is right over my exhaust, does it have to do something with the heat... what do you guys think
Old Feb 9, 2008 | 07:49 PM
z6hatchboy's Avatar
Default Re: Shifting problem after long periods of time (ramos2589)
Check your tranny fluid.
Old Feb 10, 2008 | 08:41 PM
ramos2589's Avatar
Default Re: Shifting problem after long periods of time (z6hatchboy)
People keep telling me that its my tranny fluid but its not my fluid
Old Feb 10, 2008 | 08:57 PM
InTheLBC's Avatar
If you have a hydrolic clutch, check your fluid level. Try bleeding it and filling it back up. Or your clutch could be going out. Or maybe your throwout bearing that makes the clutch catch and release could be going out. Maybe your tranny is going out. These are all problems i had with my del sol when the clutch went out and i had to limp all the way home in first gear. Replaced the clutch, pressure plate, and throwout bearing and nows shes shifting like a champ. Good luck!
Old Feb 10, 2008 | 08:58 PM
InTheLBC's Avatar
Default Re: Shifting problem after long periods of time (InTheLBC)
by the way this is all said assuming you have a manual transmission
nmb16a
Transmission & Drivetrain
Jan 31, 2010 07:43 PM
phoshizzle88
May 17, 2006 10:39 PM
honda4674
Oct 24, 2005 07:39 AM
Vi3tboy
Feb 1, 2004 02:33 PM
machine4321
Jun 1, 2003 10:41 PM
