BPi Velocity Stack with OEM Intake Arm Users
Old Feb 9, 2008 | 06:43 PM
jomama's Avatar
Default BPi Velocity Stack with OEM Intake Arm Users
HT,
2/13/08 EDIT: pictures
For those of you with this setup, how did you guys securely attach the velocity stack with the end of the intake arm? i've got a silicon band thingy in between the two (the silicon band/hose won't fit over the end of the intake arm like the BPi instructions state you should do on a normal intake pipe) and i just wedged the filter/stack up into the intake arm and just zip-tied it for now... any ideas on what you guys have done...? Thanks!
Jo
The K&N RF-1048 is one BIG *** filter:
Picture showing how it sits with the ziptie:
Modified by jomama at 9:10 AM 2/13/2008
Modified by jomama at 10:22 PM 2/20/2008
Old Feb 9, 2008 | 10:36 PM
Mr.OB*GYN_Rhett's Avatar
Default Re: BPi Velocity Stack with OEM Intake Arm Users (jomama)
isnt it meant to be used with an aftermarket intake arm with a 3" ID? idk
Old Feb 10, 2008 | 12:45 AM
frozenb's Avatar
i did the same, don't worry, they won't felt off. also u can try to zip tide the intake arm to something else to prevent movement too
Old Feb 10, 2008 | 07:29 PM
jomama's Avatar
Default Re: (frozenb)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by frozenb &raquo;</TD></TR><TR><TD CLASS="quote">i did the same, don't worry, they won't felt off. also u can try to zip tide the intake arm to something else to prevent movement too</TD></TR></TABLE>
yeah, that's what i'll probably do. user "fuko" has the stack/filter with the samco arm and he said his is just "laying" there. lol.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr.OB*GYN_Rhett &raquo;</TD></TR><TR><TD CLASS="quote">isnt it meant to be used with an aftermarket intake arm with a 3" ID? idk </TD></TR></TABLE>
it doesn't have to be. i'm cheap...
Old Feb 11, 2008 | 08:49 AM
b 1 6 b's Avatar
Default Re: (jomama)
cheap
Old Feb 13, 2008 | 08:10 AM
jomama's Avatar
Default Re: (b 1 6 b)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b 1 6 b &raquo;</TD></TR><TR><TD CLASS="quote">cheap </TD></TR></TABLE>
that's how i roll
Old Feb 13, 2008 | 09:19 AM
Dave_B's Avatar
Someone say...
B.P.I.??? Betta watch out foo!!! The Canadaians might be after you...
Old Feb 26, 2008 | 06:32 PM
chad's Avatar
Moderator
i did a back to back test with a v-stack that i have on an itr stock arm vs mugen.....
the v-stack i have which is almost identical to BPI's except mine is aluminum the v-stack made 4 more hp from 5k to redline
back to back test
Old Feb 27, 2008 | 05:38 AM
jomama's Avatar
Default Re: (chad)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chad &raquo;</TD></TR><TR><TD CLASS="quote">i did a back to back test with a v-stack that i have on an itr stock arm vs mugen.....
back to back test</TD></TR></TABLE>
badass! what else can i say? go-fight-kill's doing a bunch of dyno tests with different setups.
Old Feb 27, 2008 | 06:09 AM
GO-FIGHT-KILL's Avatar
I just ordered a Vibrant aluminum velocity stack, and a Blox aluminum velocity stack... I'm about to test all 3, back to back.
Old Feb 27, 2008 | 06:12 AM
coolhandluke's Avatar
Default Re: (GO-FIGHT-KILL)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GO-FIGHT-KILL &raquo;</TD></TR><TR><TD CLASS="quote">I just ordered a Vibrant aluminum velocity stack, and a Blox aluminum velocity stack... I'm about to test all 3, back to back. </TD></TR></TABLE>
Very cool, your efforts will be appreciated for sure.
Old Feb 27, 2008 | 06:58 AM
jomama's Avatar
dude, that's just waaay overkill. might as well borrow other's different intake systems and compare general "v-stacks on a stick" with others still, you are DA MAN. how are you paying for the time on the dyno just testing different setups? hookup?
Old Feb 27, 2008 | 07:26 AM
Todd00's Avatar
I said I don't want a title!
Is there a filter that will fit the velocity stack that's smaller than the K&N RF-1048? I haven't looked on K&N's website and researched, but I figured someone here has tried.
Old Feb 27, 2008 | 07:36 AM
jomama's Avatar
i know neo_ used this:
maybe he can comment on what p/n it was.
Old Feb 27, 2008 | 08:01 AM
Todd00's Avatar
Hmm...that filter might work better, actually. I'm going to do some measurements to see if I can utilize a modified stock airbox lower (and upper), just for the simple fact that I *hate* using zipties to hold the intake arm.
Just looks ghetto But then again a cut-up airbox looks ghetto if done incorrectly.
Best solution seems to be a 3" short-ram pipe with the bpi and filter.
Old Feb 27, 2008 | 08:12 AM
jomama's Avatar
Default Re: (Todd00)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Todd00 &raquo;</TD></TR><TR><TD CLASS="quote">Hmm...that filter might work better, actually. I'm going to do some measurements to see if I can utilize a modified stock airbox lower (and upper), just for the simple fact that I *hate* using zipties to hold the intake arm.
Best solution seems to be a 3" short-ram pipe with the bpi and filter.</TD></TR></TABLE>
i hear you on all levels. when the weather's better, i'm going to try to fab up a box that will enclose the filter so i can use the bottom half of "BSQ's" icetake... like a mugen/comptech. others are doing something similar... so many velocity stack threads in one week!!!
something siiiimilar to endyn's:
we gotta consolidate these stack threads... just use jordan's
Modified by jomama at 10:09 AM 2/27/2008
Old Feb 27, 2008 | 09:44 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jomama &raquo;</TD></TR><TR><TD CLASS="quote">
dude, that's just waaay overkill. might as well borrow other's different intake systems and compare general "v-stacks on a stick" with others still, you are DA MAN. how are you paying for the time on the dyno just testing different setups? hookup?</TD></TR></TABLE>
Our shop has an AWD dyno, so I have it at my disposal. No way in hell I could afford the time I've spent on it.
Old Feb 27, 2008 | 10:19 AM
fuko's Avatar
did i say "laying" there? my bad if i did. bad grammar FTL
i meant to say "lying"
Old Feb 27, 2008 | 03:25 PM
neo_'s Avatar
Default Re: (fuko)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jomama &raquo;</TD></TR><TR><TD CLASS="quote">i know neo_ used this:
maybe he can comment on what p/n it was.</TD></TR></TABLE>
I had that filter and intake setup over a year ago. The way I found the filter was just by going to K&N's website, and searching filter's by their dimensions. You can do the same thing here:
http://knfilters.com/search/universal.aspx
You can find pretty much any filter dimension that you desire.
Old Feb 29, 2008 | 05:53 AM
ninor's Avatar
that filter is 4600 by the looks of it carbon fiber, and it is more money than 4600 with rubber cap...
Anyway I have this for almost 2 years now at the end of aem cai, and it works great...
Old Apr 5, 2008 | 06:51 PM
steadysupreme's Avatar
As of now, I did it like jomama except i didn't use a zip tie, i used a clamp.
I didn't even have the coupling which BPI recommends, i just clamp the stock intake arm to the stack.
Is there another solution to secure the stack with stock intake arm? or i should just go 3" aluminum arm???
Old Apr 7, 2008 | 06:15 AM
jomama's Avatar
^ any pictures? i'm sure a clamp would be better just stick with the stock ITR intake arm...
Old Apr 7, 2008 | 07:18 AM
Basically, mine is just like yours, except you had used a silicone coupling in between the intake arm and the stack, and i don't have that silicone coupling.
Just i just put the stack inside the stock intake arm, the thing is the stock intake arm is way bigger than the stack's outlet diameter. That's why it doesn't seal tight even using the clamp. Or did i get the wrong stack from BPI?
Old Apr 7, 2008 | 07:20 AM
Default Re: BPi Velocity Stack with OEM Intake Arm Users (steadysupreme)
I tried putting a 3" silicone coupling over the stack and it fits perfectly but on the other hand, the 3" silicone coupling won't fit inside or outside the stock intake arm~
I might need a reducer?
Old Apr 7, 2008 | 09:36 AM
jomama's Avatar
^ not sure... my coupling, like you said, fit inside the stock intake arm... FYI, i know you just installed the 3" version of the BPI stack, but they're just about to release a 3.5" version
