Integra suspension on CRX
Old Feb 9, 2008 | 02:09 PM
tigerr227's Avatar
Default Integra suspension on CRX
Can 94 ls suspension fit my crx i mean the whole setup calipers wheel hub and all what would i have to do to convert. There is a reason why?
Old Feb 9, 2008 | 02:18 PM
Deo's Avatar
Deo
Default Re: Integra suspension on CRX (tigerr227)
In theory it might bolt up, but you'll run into some issues.
Integras tend to have stiffer spring that when used in your CRX will raise the ride height (fun if you're looking to offroad).
Switching the brakes without the corresponding Prop Valve/Master Cylinder/Booster could screw up your brake balance, increasing braking distances.
If your CRX is an 88, the rear shocks won't bolt up unless you swap Lower Control Arms (though I think you're talking about the front suspension only)
Actually, would you mind clarifying "the whole setup calipers wheel hub and all"? Do you mean front and rear, shocks and springs?
Old Feb 12, 2008 | 12:06 PM
tigerr227's Avatar
I have lowering springs on the integra so I wanted to use those but the main swap was the 4 lug hub assembly, theres a site that has a 5 lug hub for a stock 94 ls integra assembly and i wanted to put that on the integra set up then that set up on the rex. What would i have to do to get that done . Thanx also for the positive input and suggetions.
Old Feb 12, 2008 | 02:01 PM
90efhatch's Avatar
Default Re: (tigerr227)
I have 90-93 integra suspension on my hatch. I dont think the 94 up front suspension fits the ef chassis. I know it bolts up to the 92 up. I think the rear from 88-00 is the same at least password jdm says it does.
Old Feb 12, 2008 | 04:39 PM
n3h3bkau's Avatar
Default Re: (90efhatch)
The rear is the same excluding the 88 crx. They used the same type as the ITR.
Old Feb 12, 2008 | 06:54 PM
crxcess's Avatar
Default Re: (n3h3bkau)
you'll need 90-91 crx e-brake cables.
Old Feb 12, 2008 | 09:05 PM
twiztid17thninja's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90efhatch &raquo;</TD></TR><TR><TD CLASS="quote">I have 90-93 integra suspension on my hatch. I dont think the 94 up front suspension fits the ef chassis. I know it bolts up to the 92 up. I think the rear from 88-00 is the same at least password jdm says it does.</TD></TR></TABLE>
you have pics? if so i would like to see plz
gsrhatch530
Aug 16, 2005 12:35 PM
ImportRicer
Jan 30, 2005 09:52 PM
93 VTEC
Dec 10, 2004 08:50 AM
yj
May 16, 2004 05:48 PM
NoLipRacen
Oct 22, 2003 03:44 PM
